Superb 2017 Estate Blower fan removal help
Hi all,
I can't find a similar post for a Superb, only an Octavia and the assembly around the glovebox is different.
I'm working my way through a trouble shooting list and when I remove the filter behind the glovebox, I can see that the top of the fan shaft is corroded. Apparently this is common and can be sorted with the right lubricant on the shaft and bearing.
My issue is I can't drop the fan and motor unit out.  I'm wondering if anyone has removed this on a Mk3 and if there is a process I can follow?
I've removed the soft cover below the glovebox, and all off the retaining bolts, but it aint shifting. I'm hoping there's a knack, and I don't have to take the glovebox surround off entirely as it has the small blower, light and release catch attached.
Any direction is appreciated.
Many thanks
