High oil temp
High oil temp up to 110c at some points on a 66 plate Skoda octavia vrs 4x4 tdi?
Welcome.
Not very high then above the normal indicated 92 *oC or so.
110*oC indicated must mean you have good oil, a good oil level and the weather was not too hot, or you were not going that quick or the car loaded, as in it was about where it should be, and if it goes higher it should come back down to there, and as you slow and the fans do their job it drops again to near the 92*oC indicated.
Toot appreciate that 👍🏻 what would be classed as too high? Excuse me if I sound daft but I’m no mechanic 😊
If you cross the channel and the roads are good and you are fully loaded and up above 100 mph and it is around 125-130*oC you will still be fine.
If you are towing a caravan in the UK in this weather and it is up about that you are still fine.
Just out of interest & unrelated but how many miles has your car done, and has the Haldex been serviced correctly every 3 years / 30,000 miles?
So at least twice.
Are seems ok then I’ll just keep an eye on it. It’s done around 91000. the heldex got done on the last service just over a week ago
