Infotainment Amundson to MIB2.5 any regrets
I have the Amundsun with the 6.5" screen I think it is. I want the bigger 8" screen but vw-retrofit only have the mib2.5 not the mib2
I know the mib2.5 has better screen resolution but I like the tactile feel of actually pushing the buttons. Also concerned that the glass on the mib 2.5 will be a lot easier to scratch than the matt effect screen on the mib2
Anyone miss the mib2 after swapping. Thanks in advance
Edited by rit
Spelling
  • rit changed the title to Infotainment Amundson to MIB2.5 any regrets
I don't think mib 2.5 is worth it. Went from Amundsen (old one) to mib2 with the 8 inch screen. No regrets at all.
The following screens all run at the same resolution:
- Amundsen MIB2 with buttons
- Amundsen MIB2.5 with glass screen
- Columbus MIB2
The only screen which is a higher resolution is the 9.2" MIB2.5 Columbus which requires a MIB2.5 Columbus to make it work.
I've had no issues with scratching the glass screen on the MIB2.5 in my Octavia (factory fitted).
Hoping to get this fitted for £750
You should go through @pab567
He will Taylor the unit perfectly for your car.
He made the same setup for me
I cam make it definitely under £750 :). Let me know your VIN.
@ritthere you go
