Fabia Mk1 washer problem
Hi, I have an LHD Fabia 1.2 HTP, and the windscreen washer doesn't work and hasn't for quite some time. I suspect the pump as there is no noise coming from it but it could be the fuse...? When I pull the stalk forward, the wipers work ...... are they on a different circuit?  If the fuse was gone, would it knock both out?
Just got a haynes manual as trying to get an MOT on a 1.2 06plate and according to it the wiper is fuse 41 (20amp) but the wash wipe system  is fuse 15 (10amp) I assume the LHD will be the same as RHD
Alasdair
Thanks for this. Does the Haynes manual give the fuse location?
  • Sponsor
Thanks a million.
