Flashing message on display 2013 Roomster
Hi
My friend sent me the attached video and thinks it's gearbox related. I have googled everything I can think of and have no idea. Not sure if some pixels are missing or it's a message. Can anyone advise please? It's an automatic 2013 car. Thanks
Welcome.
Sorry no idea as i do not know that screen.   Someone will be along hopefully that does know.
What engine does it have, a petrol or diesel, do you know if it is a 1.2 TSI petrol or a 1.6 TDI dieesel?
I see it is in D1 in that picture.
Does the DSG change OK.
In a 2013 Roomster i assume it is a DQ200 7 speed twin dry clutch gearbox.  That is an Automatic as far as most are concerned, it is actually a Semi-Automatic according to VW Group.
Well, there's a fault in the display itself, as it's flashing between a faulty "S" and "D1".
Cheers, i did not even see it was a vid.
So no idea about between D1 & S.    On a Fabia from 2013 it might be a Flashing Spanner that appears on the Maxidot.
Some DQ200,s built late 2012 - 2015 were part of a Recall Action with no recall so a Service Campaign.  This was '34H5' and a software update as a preventative measure because of heat and pressure issues and leaking MCU.  It might have been done and it might not and there might be a sticker in the spare tyre well if it was done.
That would have a date, and 34h5 and a dealers stamp or name on it.
The accuator can be the issue if there is an issue.
There are repair kits.            Anyway a diagnosis will need done if there is an issue, or if not just to know what is up with the display.
Thanks for the speedy replies. It's a petrol car but am asking if it changes gear ok.
Hi, the reply back is: Yes but it keeps flashing the gear D1,D2 etc when normally it doesn’t flash. Uphill I felt it wasn’t changing but felt ‘lagging’. When I put on reverse it doesn’t move promptly. Takes a while to get it moving.
It needs to be visiting an Auto gearbox specialists that had experience of DQ200,s.  Best not assume that all have.
