vRS Lens Halogen Headlights Conversion
Hi All,
I am coming for an advice, as I could not find any information on web and thought, this is the last place of wisdom.
Basically, I will relocate from UK back to Czech Republic soon. I will export my 2008 Skoda Otavia vRS with me and to be able register car there, I need to convert front headlight to suit legislation. Is it possible to rebuild them for EU roads? I checked the user manual and there is only temporary solution.
Many appreciated any input from you.
Marian
1 hour ago, Nosnx said:
Hi All,
Marian
I think the only way to do what you want to to buy a set of wrong hand drive headlights. Sorry.
You would have to replace the projectors which isn't really worth the hassle as they are not designed to be replaced.
To get the old projectors out on prefl you would have cut off the headlight lens as it's permanently bonded to the housing.
Only option is to buy new headlights. I wouldn't recommend going with used because with burnt out reflectors you might as well use candles as headlights 😅
