1.9 diesel preheater relay
Where do I find the relay for the diesel preheaters on 1.9 diesel
  • Sponsor
Do you mean the glowplug relay?
If so it's in position 9 on the relay panel.
Thanks for the info re the glowplug relay.
Is there a definition of what each of the other relays are please??
  • Sponsor
Depends on year,  engine and equipment options, if you pop up a photo of your panel when you get to it I can tell you what the fitted ones do, probably. Likely to only be a few.
Replying to Pete's offer to identify other relays.
9 as you say is the preheater.
I also have -  10.2
and 3 others - all marked as type 53 - in positions  4,  and then   13 & 14.
Thanks for your help here.
  • Sponsor
Position 10.2 is described as headlight dip relay, so I guess you have the type with a single H7 halogen bulb and a moving shutter system that selects between main and dipped beam?
Pos 4 is the X contact relief relay (switches off various current consumers during engine cranking)
Pos 13 is your engine ECU relay - "Diesel direct injection system relay"
Pos 14 is fuel pump relay.
Edited by Breezy_Pete
Thanks Pete
