Škoda Octavia mk2 lost power with no error codes
Hello,
I m new to this forum so if something I said wrong you can correct me.
I drive Škoda Octavia mk2 VRS 2008 TDI 125kw model.
2 weeks after I bought the car my DPF went crazy, every 50km it required "regeneration", after I've had enough of it I went to service that removes DPF and reprograms it, they did their job and car was smooth untill now.
Everything was fine for over 2 years, untill last weekend I was driving as usual 90-100km/h 6th gear, untill I felt like "braking" but it was that my car lost power completely.
Coworker connected his computer, found some codes but they all were not engine, airflow or any turbo sensors related, he deleted all the codes and then there was none left, but my car still has no power.
Btw i can rev normally, 1st and 2nd gear I have some power but still slower than it was before, once I get into 3rd gear it almost stops and getting speed is pain...
My question: is it possible that DPF and EGR removal could cause this problem? We tried 2 different scans with no error codes, my friend checked most sensors that could cause this problem, or maybe we are looking at wrong places?
Maybe someone has some ideas here, where to look?
What were the codes he deleted?  Did you record them?
Yes but none of them were limp mode related, like speakers, lights etc.
On friday I've bring the car to electrician shop,
They said some cables are shorting, and causing this problem bur haven't heard from them since saturday.
