DAB no signal
Hi all. Been a while since I've posted. Anyways, my daughter has a 2018 Monte Carlo and she's asked if any of you " Skoda Gods " could help her.  The issue she is having is there is no signal for her DAB stations to work. Its been like this for a few months and its annoying her now. Is there anything she could do herself to rectify it ? I'm sure she mentioned she's tried a reset but I know zip about these systems and cant help her out. Any pointers would be much appreciated.
You must connect some diagnostics tool (VCDS, OBD Eleven, ODIS, Vag Can Pro, VC Tool) to check for errors.
Thanks pab 👍
Same problem here. 2018 S EL.
As pab567's reply earlier in the thread or you could try a radio reset, I'm not sure how you do that so you'll have to search for that, or it might be press and hold the on/off button until a menu screen or reset happens BUT I don't know if that's correct.
I had this on my Superb, turned out the DAB aerial wasn't plugged in to the back of the head unit.
Hi I am having the same issue Started last week on my Octavia 1.5 2018 FM works fine but no signal detected on DAB
Hi Update, I pulled out the unit in the glove box (with the 2 SD slots) and reseated the black antenna cable atvt back. Just rescanned for stations and all working now
Unit in the glove box? 2 SD slots? Only one in my 2018 Fabia
Edited by RickW
Sounds like the Octavia has two.
Some have two, some even have a SIM slot
Looks like I've missed out then🙄
