Replacing Rear Light Cluster
Had a small accident over Christmas and managed to smash in the left outer rear light cluster.  All bulbs still work but need the unit replaced as the outer plastic casing is in pieces.  There seems to be 2 options when purchasing a replacement, 1 with bulb holder and one without.  Unsure which ones I need tbh, can anyone offer some advice.
It seems to be a simple process to replace, uncover the 3 screws, undo and pull towards the rear.  Unscrew the bulbs and replace unit.  Is this all that is required?
Matt
Whats the vehicle registration and ill let you know which one is required.
There are 3 different spec lights: low, high and LED.
Thanks ApertureS
Its EO16XNG
52 minutes ago, Maffa said:
Thanks ApertureS
Its EO16XNG
    3V5 945 307 E LED tail light
(left-hand traffic only)
D >> - 30.05.2016
left inner 1
    3V5 945 308 E LED tail light with rear fog
light
right inner 1
    3V5 945 207 Tail light left outer 1
    3V5 945 208 Tail light right outer 1
Much appreciated, looks like I need it with Bulb holder  👍
