1.4 L&K spare alloys
I'm looking for a spare set of oem Origami L&K Alloys but can't seem to find anyone who sells these, cant even gind the part number.
The ones on Ebay are a bit battered, and not sure if they would be worth getting restored.
Any advice appreciated.
On GUMTREE
Hitchin, Hertfordshire
Four good used genuine 17 inch Skoda Yeti alloy wheels with part worn tyres (one with a slow puncture). 7J×17 H2 ET45 part number 5L0 601 025 AB. Genuine reason for sale.
Ad ID: 1472360382
If they are any good, make him an offer.
Edited by Carlodiesel
7 minutes ago, Carlodiesel said:
On GUMTREE
Ad ID: 1472360382
Many thanks, unfortunately not the L&K variant which is part number 5L0601025QFL8
Otherwise would have been ideal!
The Skoda parts catalogue shows that the Origami comes in three versions as shown below. Make sure any seller gives you the OEM part number because there are two versions of the black metallic Origami alloy rims.
2
5L0601025L Aluminium rim 7Jx17 ET45 5/112 57.1 4 ORIGAMI
  5L0601025L 8Z8 Diamond silver     PR-CP9
2 5L0601025Q Aluminium rim 7Jx17 ET45 5/112 57.1 4 ORIGAMI
  5L0601025Q FL8 Black metallic
burnished aluminium
    PR-CQ9
2 5L0601025S Aluminium rim 7Jx17 ET45 5/112 57.1 4 ORIGAMI
  5L0601025S FL8 Black metallic     PR-CY9
https://www.lllparts.co.uk/catalogs/skoda/CZ/YET/779/6/601/601070
Edited by Carlston
2
burnished aluminium
    PR-CQ9
Thank you, that is brilliant, at least this give me a starting point. Skoda main dealership want £2.2k for a full new set 😞
£2,200 will be from the expensive factory catalogue.
Skoda also do an alloy rim accessory catalogue, which tend to cost about 40% of the typical factory price...so a massive 60% saving...or put another way the factory rims cost about two and a half times the price of the accessory price.
So you can get a set of four new 7Jx17 ET45 5/112 57.1 alloy rims for about £720 to £760...at least in the two examples below.
In the below two examples, the xxx071xxx format means that its from the much cheaper accessory catalogue. Skoda are using their accessory catalogue to compete on price with aftermarket alloy rims.
Although the below alloy rims are listed for the Karoq, they are the same 7Jx17 ET45 5/112 57.1 specification as the 17" Yeti rims. The Karoq 2x4 fits 215/55R17 to these rim, and the Karoq 4x4 fits 225/55R17 to these rim. So the Yeti's 225/50R17 is different, but that isn't a problem.
7Jx17 ET45 5/112 57.1 alloy rim 57A071497C 8Z8 (5199CZK is about £180 each)
Alu kolo Ratikon 17" Karoq
 https://eshop.skoda-auto.cz/cs_CZ/alu-kolo-ratikon-17-karoq/p/57A071497C+8Z8
7Jx17 ET45 5/112 57.1 alloy rim 57A071497D FL8 (5459CZK is about £190 each)
https://eshop.skoda-auto.cz/cs_CZ/alu-kolo-ratikon-17-karoq/p/57A071497D+FL8
For even bigger savings, you could use a non-standard 17" steel rim from the Kodiaq...perhaps together with a non-standard 215/55R17 tyre size. You might choose this option if you want to run 215/55R17 tyres rather than the standard 225/50R17 on the Yeti.
6.5Jx17 ET38 5/112 57.1 steel rim (from Kodiaq) (£53.98 each)
ALCAR 9021
https://www.autodoc.co.uk/alcar/14750807?search=ALCAR+Rim+(9021)
Edited by Carlston
For even bigger savings, you could use a non-standard 17" steel rim from the Kodiaq...perhaps together with a non-standard 215/55R17. You might choose this option if you want to run 215/55R17 tyres rather than the standard 225/50R17 on the Yeti.
ALCAR 9021
Thanks so much for this information, and good to know about the accessories catalogue.
Can't believe the price difference between the one i have 5L0601025SFL8 and the other ones.
Keen to try and source an exact match if I can get them a bit more reasonably priced, is it only main dealers that sell these or can they be located through other supply chains?
Worst case will compromise and get one of the above
