Radìo
component protection
  • Administrators
@MarkButtonwelcome, we’re going to need a little more information to help you on this one.
Please reply below with your problem, question, information etc.
I've replaced the multimedia unit, with another, from a different vehicle, will this work, and, if so, how ?
Need to know a lot more:
- it appears you have a 2019 Octavia (is this correct?)
- what model of infotainment unit was fitted? Swing, Amundsen, Columbus, ...
- do you have Canton?
- what vehicle did the unit you have fitted come from (make, model and year)?
- what model of infotainment unit is it?
Almost certainly not. The car's body control module will presume that the "new" ICE has been stolen until it is provided with a code number.
The use of a code was removed many years ago and replaced with component protection (which can only be removed by a dealer or an independent with online access to the VAG servers).
