Front suspension parts help
Hi all
can anyone confirm these front Sachs parts are correct
replace rears a good while back and had incorrect ones
so here goes
Sachs 317-575 front shockers ( 3C0 413 031AT Sticker on shocker)
Sachs 993-061 coil springs
colour code on car spring is
Orange
Green
Yellow
Yellow
Sachs 802-417 Top mount/bearing kit
Sachs 900-136 Dust/Bump stop kit
car is a 2013 estate 2ltr tdi 170bhp manual
pic of build spec included
cheers all
3C0411105C Front coil spring L03
1 orange paint mark
1 green paint mark
2 yellow paint marks
Sachs 993061 front springs match 3C0411105C. However, Kilen 25068 and KYB RH3559 are much cheaper and also OE quality.
3C0413031AT Front shock absorber G07
Sachs 317575 front shock absorbers are sold to replace a huge number of OEM part numbers including 3C0413031AT. Cars listed against this shock absorber include smaller cars such as the Octavia MK2 and Golf MK5/6.
Bilstein B4 22-151056 front shock absorbers are sold to replace a much smaller list of OEM part numbers than Sachs 317575, and smaller cars such as the Octavia MK2 and Golf MK5/6 aren't listed against them. For these reasons my preference would be the Bilstein over the Sachs. However, if you already have Sachs front shock absorbers I can understand the desire to match the brands.
The below Sachs parts look ok
Edited by Carlston
hi Carlston
so reading your post I seem to have the correct Sachs items for Shockers and Coil springs
why I’ve picked Sachs is cos that’s what I fitted on the rears
This is pic I found back tracking through some photos I had and it showed the colour dots on spring
cheers
It was easy to find the correct front spring because of the L03 build code on the white build code label...and the coloured dots on your photo confirms this, ie. orange, green, and two yellows.
Edited by Carlston
Thanks very much for your help, it’s much appreciated
I don’t know what all them numbers mean on the photo
I had the photo because I was looking for the engine code once
cheers again
Stephen
Type up all the 3-digit build codes and copy and paste them into the VW codes decoder. However, there's only 46 of them shown on your white build code label when in fact the car has a lot more build codes than what's shown...perhaps around 180 build codes. There's a seller on ebay that can supply all your car's build codes. Link at the bottom of this post.
E0A 1N3 4A3 7T6 3L6 7AL 1D0 1NL 8ZF 8AY 9P3 G07 5SJ H7D J0L 8QL Q2J L03 5RV 4UP QI6 8X1 7X1 7P1 1KJ 8GU 4K3 9ZG F0A 6FB B09 6Y0 B09 8WD 1AT 3QT 9AK 7MG 7A0 3S9 3FA 4X3 8RM QN0 3GG 2UA
E0A = No special edition
1N3 = Speed-related variable steering assist (Servotronic)
4A3 = Seat heater for front seats separately controlled
7T6 = Navigation system (MID)
3L6 = Electric seat adjustment for both front seats, drivers seat with memory system
7AL = Anti-theft alarm system, passenger compartment control, backup horn and towing protection
1D0 = Without trailer hitch
1NL = Covers for alloy wheels
8ZF = Inside side window antenna
8AY = Radio/navigation system
9P3 = Seat belt reminder, electric contact in buckle
G07 = Front shock absorption
5SJ = Left exterior mirror: convex
H7D = Tires 225/40 R18 92Y xl
J0L = Battery 340 A (70 Ah)
8QL = Key for locking system with remote control
Q2J = Comfort front seats
L03 = Suspension range 03 installation control only, no requirement forecast
5RV = Right exterior mirror: aspherical
4UP = Drivers and front passenger air bag with knee air bag and front passenger air bag deactivation
QI6 = Service indicator 30,000 km or 2 year ( variable )
8X1 = Headlight washer system
7X1 = Park distance control
7P1 = Power adjustable lumbar support in frontseats
1KJ = Disc brakes, rear
8GU = Alternator 140 A
4K3 = Radio remote controlled central locking operated from inside and safe securing
9ZG = Mobile phone preparation with hands-freespeaking system
F0A = No special purpose vehicle, standard equipment
6FB = Body-colored exterior mirror housings
B09 = Type approval Great Britain and NorthernIreland
6Y0 = Without cruise control warning system
8WD = Integrated front fog light
1AT = Electronic stabilization program (ESP)
3QT = 3-point seat belts with tensioner and height adjustment, front
9AK = Climatronic with impact pressure control free of cfc
7MG = Emission standard EU5
7A0 = Without CD changer/CD player
3S9 = Roof rails
3FA = Without roof insert (standard roof)
4X3 = Side air bag front with curtain air bag
8RM = 8 speakers (passive)
QN0 = Without drawers under front seats
3GG = Plane rear cargo area
2UA = Standard design
VW Codes Decoder
https://igorweb.org/equidec.aspx
"skoda vin decoder"
https://www.ebay.co.uk/itm/224631127243
Edited by Carlston
3S9 = Roof rails
VW Codes Decoder
😳 WOW
3 minutes ago, Snapper1725 said:
😳 WOW
Notice that the build codes for the front brakes, rear springs, and rear shock absorbers aren't shown...hence it can be handy to have the full list of build codes.
Edited by Carlston
No not yet,  am still trying to figure out the L03 code to how you can tell which springs/shockers are correct
G07 for shockers
Edited by Snapper1725
32 minutes ago, Snapper1725 said:
...am still trying to figure out the L03 code to how you can tell which springs/shockers are correct
G07 for shockers
You can see in the Skoda parts catalogue that 3C0411105C is listed against build code L03, and 3C0413031AT is listed against build code G07.
2013 Superb MK2 estate front suspension
https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/632/4/411/411001
Edited by Carlston
That’s great
thank you 🙏
cheers
