Roomster 5J central locking problem
Roomster 1.2 tsi 2012
Just wondering if anyone has any ideas about my central locking problem. I have searched the forums but not found the exact fault I am experiencing.
Tailgate appears to work as normal but the other 4 doors do not lock. Drivers door can be locked with the key but the others remain unlocked. The fob can then be used to unlock the drivers door. A click can be heard on all 4 doors when trying to lock or unlock with the fob. The locking button on the centre console has no effect locking but unlocking triggers the same click in all doors.
I have repaired a few wires previously in both front door gaiters but can't see anything currently broken. Windows working as normal. Open door indicator on the dash working as normal.
Got a friend to read the error codes which came back as below following a reset. Many thanks in advance for any advice.
Address 09: Cent. Elect.       Labels: 6R0-937-08x-09.clb
Control Module Part Number: 6R7 937 087 K    HW: 6R7 937 087 K
  Component and/or Version: PQ25 BCM      H27 0531
           Software Coding: 25980B3808C92400923808002C2B08C00040400F60000000020000000000
            Work Shop Code: WSC 13765 790 00126
                      VCID: 4CD48360EF12A3F16F-8018
5 Faults Found:
00532 - Supply Voltage B+
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 142
                    Mileage: 85315 km
                    Time Indication: 0
                    Date: 2024.02.11
                    Time: 15:15:09
03301 - Response Closing Status of Drivers Door
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 85315 km
                    Time Indication: 0
                    Date: 2024.02.11
                    Time: 15:17:24
03302 - Response Closing Status of Passenger's Door
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 142
                    Mileage: 85315 km
                    Time Indication: 0
                    Date: 2024.02.11
                    Time: 15:17:24
03303 - Response Closing Status of Rear Left Door
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 142
                    Mileage: 85315 km
                    Time Indication: 0
                    Date: 2024.02.11
                    Time: 15:17:24
03304 - Response Closing Status of Rear Right Door
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 142
                    Mileage: 85315 km
                    Time Indication: 0
                    Date: 2024.02.11
                    Time: 15:17:24
Update to this
Discovered this morning that the centre console button would sometimes (not every time) lock all doors when the engine is running and having locked and unlocked it a few times it now locks and unlocks with the fob again as normal. Wondering if this could be a sticky relay or a bad connection somewhere.
Sounds to me like a sticky centre console button. Have you've spilt your coffee over it at some time?
Not I but it could well have something in there all the same. Might try taking it out and cleaning it. Thanks for commenting.
