Usb socket removal
I need information about replace and installation Usb socket, which used for Android Auto. See bellow photo for additional info.
downloadfile.PDFdownloadfile(1).PDF
Can anybody give advice how to take off part that hold front USB socket? Thanks.
I need to exchange it or replace USB socket itself as it is broken.
I do have same with minijack, probably same way to remove. Just start pull it with plastic tool from sides
I could be wrong but I seem to recall looking into this a while back when I thought the one in our Kodiaq had failed.  From memory if you remove the trim panels either side of the footwell you may be able to get at the clips holding that whole panel in and push it up and out which should give you access to remove the socket.  Beware though in terms of replacement as there are some that are power only and some that allow data transfer too.
