Clutch problem
I’ve recently bleed the brakes after the solid pipe cracked behind the calliper, I’ve noticed I’m still loosing brake fluid but can’t seem to find any leaks, I’ve now experienced a problem with my clutch where out of nowhere the clutch would not disengage, turn the car off and the clutch pedal would stick down, pull it back up and then working back to normal. After coming to a stop it seems to do this, maybe air in the clutch ?
