Octavia VRS MK1 A/C pressure sensor location
Any Octavia vrs mk1 owners know the exact location of the air con pressure sensor?
I haven’t had air con for a few years , but recently got it gassed and then still none.
Running vcds it found the air con pressure sensor code showing.
Ive purchase a switch and then I began to fit, what I thought was the pressure sensor. Either I’m in the wrong place or the new part is wrong.
On the air con compressor there’s a pipe coming of that has a sensor with electrical plug. I thought this was it but the new part is slightly smaller and has three electrical outlets whereas the original, or what I thought was it, has two.
googling the part number , I believe I do have the right part, so I’m probably looking in the wrong place!
any ideas??? TIA
Edited by Ade3277
  • Sponsor
Can you message me with your VIN, or just post it here?
from what I remember its on the bulkhead, turbo inlet pipe area.
Have a look in here, air con' is in Section 87 Page 50, I think its item 2.
Note the picture shows a L/H drive car so its on the opposite side :-
Octavia Vrs Air conditioning.pdf
Edited by Silver Bullet
