MOT long list of advisories
Recommended Posts
The car just passed it's MOT by the skin of it's teeth.
I've been quoted with parts and labour nearly £800, that's not including the exhaust or tyres.
I had the front tyres replaced, and it's only outer part of the silencer that's corroded.
The front tyres lasted well as I had them put on 12 years ago when I first got the car.
Edited by Lynn67
Link to comment
Share on other sites
How much tread left on the tyres?
Does that quote cover every item on that list?
I would ignore some of them, like the exhaust corrosion, and possibly the brake hose ferrule corrosion, probably even the console bushes if you haven't noticed any handling problems or graunchy noises with the car.
  • Like 1
Link to comment
I've had the exhaust advisory on the last 3 mot's but the inner case is fine so I just ignore that one.
There was plenty of tread on the tyres still, but that's not included as I get my tyres done somewhere else.
Link to comment
I would keep the tyres for another year if there's plenty of tread, imagine if you put a new pair on and got an unrepairable puncture in one soon after.
Where's the oil leak origin, did they say?
Can be due to the oil separator on the back of the engine being clogged, causing excess pressure in the crankcase.
Link to comment
Posted (edited)
The oil leak is at the front of the engine, possibly the sensor as it's a very small leak.
Two part worn tyres are £60 and they are nearly new, it's not worth putting new tyres on now as I do low mileage in a year.
Edited by Lynn67
Link to comment
Personally, I'd swap the front tyres with those on the rear. The fronts get a lot more pressure placed on them the rears and if they were to blow in use they are safer at the back than the front.
Link to comment
Have a close look there, and around the cam cover, for loose bolt(s). I've fixed several oil leaks (not just on my car) by tightening up loose bolts.
  • Like 2
Link to comment
Over the years I've had various advisories which haven't been done, only for the following year it not be mentioned
Examples include:
In 2012 I had 2 advisories about the windscreen - never changed it & hasn't featured again
2015 - an advisory for a noisy wheel bearing, never changed it & 50k miles later still not mentioned again
Don't get hung up on it.  I had a similar one for brake hoses but i did change them myself.
My back box was corroded on the outer skin so I just pulled away the rough looking bits.
The antiroll bar links might be worth doing before the next one
Also one year my car was going to fail because of the factory fitted xenons - nothing to do with alignment, the garage thought they were modified which isn't allowed. I argued & showed them the original order form & page in the manual which shows the D2S bulb, they then passed it
  • Like 2
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
