Battery light blinking at idle and rpm not stable
Recommended Posts
Hi
I've just started having problems with my 2011 skoda fabia.
There is a relay clicking in the dash and the battery light is coming on intermittently and the rpm is not stable it goes up and down a bit.
I have diagnosed it via the odb port and got the following fault codes.
P0018F5:
Crankshaft position - camshaft position correlation bank 2 sensor A
P002E40:
B camshaft profile actuator A control circuit low bank 2
P0135:
02 sensor heater circuit bank 1 sensor 1
I have a brand new battery that I swapped out 2 months ago and the problem started yesterday randomly
Link to comment
Share on other sites
Which make me thing of a dying alternator and idle stabilisation control. Ask at a reputable indy garage near you.
Link to comment
Is there a way to test the alternator to rule out any other problems?
Link to comment
Again "Ask at a reputable indy garage near you."
Link to comment
22 hours ago, sepulchrave said:
Yes, but you need a multimeter.
I've got one. Where do I test and what voltage is considered normal
Link to comment
Just check DC volts across the battery before and after starting the engine, you should get 12.7V from a healthy battery before starting the engine and something around 14.4V with the engine running.
To check rectification test for the presence of any AC  voltage when running. Post results here.
  • Like 1
Link to comment
I've done some testing now and the battery voltage was low so charged it up and the battery waring light diapered but the relay is still clicking and when I rev the engine to 2000rpm I still only get around 12.5v and not 14 v I've checked the alternator main fuse and it's intact so it is probably the alternator that's gone bad?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
