Fault code help
Hi, just plugged in and retrieved the following report using a neighbours tool.
Would like to understand then please as the same code appears in the brake section as well as other sections. I think that maybe it could be one fault cause a few.
Please ignore the air sensor and door mirror switch codes. I know about them.
I did sit for about 3 hours with the ignition. On and off to check time and clear screen. Maybe battery went a bit low causing these.
I have cleared them and will check again in a day or two
All help appreciated
I forgot, it's a 69 plate superb estate dated January 2020, it's a 2.0 TDI SE technology.
No engine light.
