Fabia MK3 1.2 TSI - AC does not work on hot days
Hello everyone,
The car I have is: Skoda Fabia MK3 Kombi 1.2. TSI 110KM 2015
Problem: The air conditioning stops working at temperatures of 30°C and above. When it's colder it works normally.
The car has automatic air conditioning.
What was fixed:
The car was at the air conditioning service and they replaced the air conditioning compressor control valve.
The service couldn't find anything, so they acted blindly.
The only trace that was on the computer and was repeated when there was a cooling problem:
590081 [0x090101]
B10A911: Activation A/C compressor, Short circuit to ground
Activation_A/C_compressor_SCG
Bity stanu: 1
Priorytet: 2
Częstotliwość: 2
Indeks: 37
Drogomierz: 147802 km
Data, godzina: 2024.04.09 17:49:31
Paramteric values:  26 00 10 26 01 FF 26 02 00 02 86 82 26 09 9D F4 0C 0E 1A
Status: Oczekująca, Potwierdzona
After replacing this valve, unfortunately the problem still persists.
I read somewhere on the internet that it may also be the fault of the air conditioning panel.
Not thinking much about spending blind money at the service center, I ordered an air conditioning panel.
I only ordered a newer 2020 Fabia 1.0 TSI car model.
After installing this new panel, everything seems to be working, but in fact whether the AC is "on" or "off" makes no difference. The air conditioning generally does not work, everything else works, but the air conditioning does not work even on a colder day.
When the new panel is installed on the computer, there is an error:
590087 [0x090107]
B148815: A/C clutch, Open circuit/short circuit to B
A/C_clutch_SCB_OC
Bity stanu: 1
Priorytet: 2
Częstotliwość: 1
Indeks: 3
Drogomierz: 147857 km
Data, godzina: 2024.04.11 15:23:14
Paramteric values:  26 00 06 26 01 00 26 02 00 02 86 81 26 09 8F F4 0C 0B 9E
Status: Test się nie powiódł, Oczekująca, Potwierdzona
With the old panel, at least it works on cold days, but with the new one it doesn't even work on cold days.
Is it possible that the new panel has different parameters and is simply trying to start a different compressor than the one in the car? Maybe someone has an idea how to solve it or has already had such a problem with air conditioning.
Have you tested the radiator fan(s)?
Inability to sink heat out of the condenser might be why it works under non-challenging conditions, but switches off when ambient temps are higher?
Somewhere in the measuring blocks of the HVAC module you should see a so-called 'shutoff code' that may give you useful info about why the A/C is switching off,  if it is actively being commanded to.
Lots of related info here:
https://forums.ross-tech.com/index.php?threads/633/
At the service center, they checked the fan, tightness and pressure. On cold days like today 15°C, you can't tell that something isn't working. No errors on the computer, when we set the temperature to the lowest "LO" it is as cold as a refrigerator.
The service now suggests that either the air conditioning compressor needs to be replaced or there is something wrong with the electrics.
Ok, I'll check what you wrote about shut off code. Thx
One "thing" that could cause it not to work when the weather is warmer is, if it has been over charged with frig gas, these systems, I think, require to be "critically charged" as a maximum charge - which is why the label under the bonnet states the total weight of frig gas to be loaded back in.
But, I'd expect a fault code to get logged stating that, ie "high pressure limit reached" - you might find out more or even that when you check the shut off code.
My wife's August 2015 VW Polo, when it was new, used to throw out the odd fault code like the first one, but then these Sanden compressors were known to have been shipped out with manufacturing debris inside them, that car's AC eventually stopped throwing out these fault codes, the thing was, at that time that car was in constant use and the fault codes were being "cleared" after a few engine starts automatically(progress?), so any chance of getting that problem resolved within warranty was not really going to happen.
Edit:- for the time being, I'd be inclined to refit the original control panel just in case its S/W is different and so not suitable for use with your age of car - at least you know that the original controller allowed the system to operate at lower outside temperatures.
Edited by rum4mo
Did you find a solution? My fabia is having the exact same issue.
