Clutch cruise controll switch Need help
So been tryinf to do a switchable remap on the car for eco and some power for some track days And daily use did it mapped it and it does not worl came to the conclusion the Cruise controll clutch switch is dead And vagcom confirmed this Has anyone ever replaced one where abouts is it located and any tips/tricks thanks
  • Sponsor
Super easy, once you get the lower dash trim off in the driver's side footwell.
There's a good guide to doing that in the guide for changing evaporator temperature sensor.
https://www.briskoda.net/forums/topic/61180-fabia-evap-temp-sensor-how-to-with-pics/ Download the pdf version to see the pics.
Clutch switch just turns 45 degrees to release from above pedal, opposite twist to fit new one.
Is this not just for the clutch switch the one i need is the one for cruise controll clutch switch or is they the same thing
  • Sponsor
Same thing.
