2016 Tdi Estate - Front Pads Replacement
Looking to change my front brake pads shortly so just checking there are no hidden steps over & above the standard remove pads, reset caliper pistons & replace pads method? eg no need for VCDS to reset or register the changeover?
No hidden steps, just regular replacement. No need for VDCS or the like.
Only thing to bare in mind is rotation oriented pads, I believe the Skoda has them so when replacing make sure you don’t mix them up
Excellent! Thanks petrolcan.
Thanks for the heads-up. I'll keep a lookout for this.
Probably has a pad wear indicator -so need to unplug the wear sensor cable on one side / for one pad only ( think its in the right side caliper) and fit the correct pad/ cable to the same place, but no diagnostics etc involved for this !
Just picked up the new pads and there does indeed look to be only one pad with a built-in sensor.
Do they have the half moon on them? Or at least an arrow?
Nope, nothing. All four pads are identical bar the one with the wear indicator attached.
They are DriveTec ( GSF brand ) btw
Edited by Gammyleg
LAst line added
Ah
Ah might be why, when you remove your current ones if they’re standard ones you’ll see the crescent
I’ll be changing my fronts at some point and going with ate ceramics, fed up with brake dust these days
Yeah, when I changed the rear pads last year I fitted the DriveTec ones then, and it looked like I had a daily commute through the Sahara for about a month afterwards. Extremely dusty but it's calmed down now.
Correct, it is the offside ( driver's side) that has the wear sensor. Unfortunately I managed to damage the connector that runs from the car to the pad when trying to disconnect it. It's become quite brittle over time and it fractured when I tried to wiggle it loose with a pair of pliers. I can see the bare wires now and there exposed to the elements so the first bit of wet weather will doubtless set off the warning light.
I don't have the requisite glue/sealants with me at the moment so will have to take another look tomorrow.
The only crescent visible was on the original pad with the wear sensor. It was indented on the back plate of the pad but seemed to line up exactly with the contact area of the caliper piston which is odd as it means that the piston is not in full contact with the back of the pad.
Anyhoo, done for the moment, I've taken it out for a quick spin round the car park and all seems in order. 50 mile trip home shortly should fully confirm success....or not.
Yeah that’s correct the piston doesn’t touch it or at least not straight away, it’s meant to stop squeals etc and improve wear rate, allegedly :)
Oddly, even though the weather was extremely wet, the first 150 miles went off without a hitch. Once it dried out though  the warning light came on. I suspect that the wires are now touching which is what's set it off.
I think I'll cut off both connectors and apply some solder & heat shrink to fix.
I am wondering whether the brake pad warning light being illuminated would constitute an MOT failure?
6 hours ago, Athrx said:
It's under £20 on ecp
Thanks for the heads-up, however it's the connector attached to the loom, not the one on the sensor that's toast.
