MiB 3 from 0270 to 0330
On 25/08/2025 at 20:43, Cairus said:
. Check this...
Password send PM
https://mega.nz/#P!AgBjIVaAPhBAV0eYvlLxnOxxeE38a7UgAG6X3agCdgtWJa94QjnCNJYzFc-PTaldmEEy3IBj_PmAV7FqW5xtTm8JIwlNCdBZrajLv8biP7-kX1bnse-VOg
Hello,
can you please PM me with the password? I am too new to send you a PM. Your help is greatly appreciated. Also, if you have 324, I would appreciate that, too. Many thanks!
  • Replies 72
  • Views 31.4k
  • Update 332 is in mibsolution.one https://mibsolution.one/#/1/9/MOI3/Preh/EU/Skoda
  • I’ve just done it - seems to work fine. Download the whole folder, extract to the root of your usb stick and you’ll see the data and meta folders extracted. Ditch the other zips after that so there is
  • https://mibsolution.one/#/1/9/MOI3/Preh
Also @Rainesh : is there a way to obtain 324 for MIB3 Skoda Columbus? Do I need it to jump from 308 to 330 or 332? I read somewhere that my datasets could be affected and an intermediate update to 324 on the way to 330 or 332 would reduce risks. Actually mib-helper also recommends 324 in case of a 308 fw. Thanks for your input.
  • 7 months later...
Hello guys,
As I have the pretty same version of device 3V0035816B, hardware H22 and software 0270 on my Skoda Superb MIB3 EU, I would like to take the same path as it has been described at the beginning of this post: (0278 -> 0306 -> 0308 -> 0324), however I can't find anywhere the 0278 version and mibsolution.one is down for couple of days already.
Does anyone have these firmware versions somewhere to be downloaded please? Or at least the 0278 one?
Thank you in advance
Regards,
Maty
No warrenty
https://mega.nz/file/RyEBBLQY#bZEOg82t7NKvPc91etLUHAzi42wPMtfr-rRtCPZj7rM
Might not need it? Can you go straight to 308?
main.mnf of 0308:
"SupportedTrains": ["*_?268*","*_?270*", "*_?272*", "*_?274*", "*_?276*", "*_?278*", "*_?300*", "*_?302*", "*_?304*", "*_?306*", "*_?308*" ]
332 is too available.https://mibsolution.one/#/1/9/MOI3/Preh/EU/Skoda
https://disk.yandex.ru/d/p21TSZ9mKJcTVQ
With 0308 straight I was getting Checksum wrong error - the hash code for the manifest file not found...
With higher versions I am always getting version not supported error. So maybe the zip file with 0308 I found somewhere is missing something?
As I mentioned, the place where it was all in one, mibsolution is down, so I am searching and downloading files here and there :-(
Thank you all for the links so far, I will try that with the 0278 first what will happen...
https://mega.nz/file/dgNAADwQ#h7p60yQb9OmM0pQ2O9nZvIPsi_k9TMnwOm83pBj3hmY
This one was installed in my car.
Thank you all for links, I will try it and let you know the result
Hello all, so I've just installed the MOI3_EU_SKMQB_R23802P + P26810P + P27800P version and all went smooth, but it wont let me go now to 308, it is checking some files and then suddenly ERR with no more details and cancel or retry option only. Maybe I should go to lower version than 308, like 302 or 306?
It appears corrupted files.
Now different error: File not found or not valid... "/media//sda1/Meta/emmc/hmi/ext-freetype/246.0.1.mnf"
I am trying to format new USB key and try that out again...
OK, new USB key helped now, it's freaking crazy how sensitive this is...
I am on 0330 now, thank you for your help guys.
Now trying to load new maps from USB, does anyone know how long it take to find out that the maps version has been changed? Funny there is no progress bar about updating of maps, leaving everyone just guessing what is happening in the background...
There is v332 out @Maty - I've got it here which is the version running on my car.
Thank you Travs, I am on v332 now too.
Regarding maps update, I have prepared 2 same USB keys (64GB) with VW maps on them, one as exFAT and one as NTFS format, both inserted in 2 USB-C ports in the center console at the same time. Result - it worked, several restarts of the device happened and after an hour or so of driving a new version of DB with Navigation Data appeared (from 20.7 to 26.2).
However, I don't know now which USB format (exFAT or NTFS) was actually the right one...
Well if doing two versions works, then that might be the key to it. Either way, good stuff.
On 14.05.2024 at 0:37, wkexe said:
Salut, dețin un Skoda Superb 3 – a fost fabricat în ultimele luni ale anului 2020 și este modelul anului 2021. Văd că toți cei de pe forum au început actualizările de la cel puțin versiunea de software 0278 și am (bănuiesc că din cauza primului lot de facelift) software-ul 0270 și vreau să-l actualizez la 0330.
Dispozitivul meu este 3V0035816E, hardware H22 și software 0270, Polonia.
Am găsit o „cale” către software-ul descărcat pentru formularul 0324 0278 (0278 -> 0306 -> 0308 -> 0324) pentru versiunea dispozitivului meu:
306 SK20220407SW306_MOI3_EU_SKMQB_P30603P
308 MOI3_EU_SKMQB_P30800P_0308
324 MOI3_EU_SKMQB_P32400P_0324
Am două probleme: îmi lipsește fișierul 0330 și nu știu dacă trebuie să actualizez mai întâi formularul 0270 la 0278. Știe cineva dacă trebuie să actualizez mai întâi formularul 0270 la 0278 sau pot trece direct la 0306? Dacă da, ați putea oferi un link către pachetul de software de la 0270 la 0278?
Și la fel de la 03:24 la 03:30 – nu găsesc coletul.
Am făcut niște investigații proprii și am citit „main.mnf” din fiecare pachet, iar pachetul 0306 spune:
"Trenuri acceptate": ["*_?268*",   "*_?270*",   "*_?272*",   "*_?274*",   "*_?276*",   "*_?278*",   "*_?300*",   "*_?302*", "*_?304*", "*_?306*"],
Presupun că acestea sunt informațiile despre ce versiuni anterioare de software sunt acceptate pentru actualizare? Dacă da, software-ul meu este tehnic pe listă. Dar, dintr-un anumit motiv, facem 0306 până la 0308 și, în teorie, am putea face 0278 până la 0308 direct, deoarece în fișierul main.mnf 0308 scrie:
„Trenuri acceptate”: [„*_?268*”, „*_?270*”,   „*_?272*”,   „*_?274*”,   „*_?276*”,   „*_?278*”, „*_?300*”,   „*_?302*”,   „*_?304*”,   „*_?306*”,   „*_?308*” ]
Dar facem 0278 până la 0306 și apoi până la 0308,
Și 0324 spune:
"Trenuri acceptate": [ "*_?308*",   "*_?310*",   "*_?312*",   "*_?314*",   "*_?316*",   "*_?318*",  "*_?320*",   "*_?322*",   "*_?324*" ],
Deci, ar trebui să fii cel puțin pe software-ul 0308 pentru a încerca actualizarea 0324.
Actualizarea după 0270 îmi va afecta navigarea, așa cum a menționat altcineva aici, actualizând de la 0156? (https://www.briskoda.net/forums/topic/512288-update-my-car-from-0156-to-0306/)
Voi fi foarte recunoscător pentru orice ajutor 😊
Salut. Eu am.un S3 din 2021, varianta MOI3 274 si vreau sa l aduc la 324. Ma poți ajuta cu fisierul firmware ptr update. Eu nu le găsesc pe MIB solution sau MIB helper. Mulțumesc!
On 26.10.2025 at 10:13, zrlaszlo said:
Buna ziua,
Poți te rog să-mi trimiți un mesaj privat cu parola? Sunt prea nou ca să-ți trimit un mesaj privat. Ajutorul tău este foarte apreciat. De asemenea, dacă ai 324, aș aprecia și asta. Mulțumesc mult!
On 14.05.2024 at 12:47, wkexe said:
Ok. Am făcut actualizarea azi. Am trecut de la 02:70 la 03:08 și apoi la 03:24. Totul a mers bine, navigația funcționează. Caut o actualizare de software pentru 03:30 - Dacă cineva ar putea împărtăși un link, aș fi foarte recunoscător 😊
Salut am aceeași versiune pe care ai avut o si vreau sa fac si eu update la 324. Ma poți ajuta cu fișierele? Mulțumesc!
If you're based in EU then you can update to 308 and then from there to 332. 324 is not the latest. If you're not EU, then the RoW (Rest of the World) files are a little harder to find.
Hi good people. I have MOI3_EU_SKMQB_P33000P (Software version 0330). I cannot find anywhere info for 332, can somebody provide more info? I though when having thsi online package, this was suppose to be available from inside the car, but when I go to setup, software info, then update, its empty. Any way to get the official update? And how do I update this, just transfer to usb-c and stick it in?
Edited by LaMpiR
I've got a link in a post last friday about 7 or 8 posts above which has it.
Unzip to an empty USB stick in the root, plug it in, press and hold Menu button which will reboot the MIB into engineering mode (black screen with small red font) and follow the logic on there; its all touch screen and some options seem to need selecting twice. Otherwise, if I can do it without an instruction manual, you're good to go.
