2015 Skoda Octavia Mk3 Headunit upgrade
Hi, i would like to ask for info and what others may have already installed, into a 2015 Skoda Octavia.
I would like to upgrade to Android auto system, still using all the wheel and factory buttons
Best option is for OEM swap. You'll need a new screen and glovebox unit. Component protection removal from the glovebox unit by a dealer. Then the new unit recoded by someone like @pab567 to make sure all the features work. Alternatively he can likely sell you a ready to go unit.
Component protection removal from the glovebox unit by a dealer is not required, unit can be patched, in Plug&Play version ;)
Gday thanks all.
Can i patch the existing glove box unit and install Android auto on the system i already have ?
Sw train Mhig
Part 5e00350450
Hardware h44
Software 0371
Hi Pabs the unit i have is this
5E0035045D
My understanding this unit cannot be updated to android auto car play with software alone , do I have to just replace the in glove box unit ?
Is there any plug in devices to bypass or use as a third party by connecting a USB stick and running it through media.
Pls share your VIN to identify if anything else but glove box unit must be replaced
TMBKE9N E2F0186779 CHEERS
