Skoda Octavia Mk3 2019 Reverse Parking Camera Installation
Hello Everyone,
I am looking to install reverse parking camera on Skoda Octavia 2019 MK3 , retrofit the camera vision in the Skoda Existing Display. I would like to have an advice on which product to buy and how to install ?
Attached is the picture of the dashboard.
There are loads of links on how to retrofit a camera (at least on Briskoda).  Depends on your budget; you are confident with electronics and don't mind use a cheap-chinese camera, then you can do it for under a £100.  I would, however, spend out on a proper VAG camera. The genuine ones come with rear washers build-in and a far better image and less lightly to fail.   Whatever you do, it involves taking out lots of trim along the passenger side / trim clips and run cables to the boot.  Once wired in to the back of the MIB system, its then a couple of coding options needed to enable up the camera.
Hi, Thanks for the detailed guidance, it really helps.
Just to ask if you can post a link if camera probably with washer option which won't need any coding and straight gets into the place.
I can do some back and forth in terms of the installation but not coding.
