Engine oil ?
Ok so, the sticker under the bonnet of my 2023 rs TDi says 0w 30 oil . How ever every where else I google for buying oil online is saying 5w 30 .
what’s the difference , would it matter and what are people using on here ?
I'd stick with the 0w30 longline 3 FE I think it should be, at least until your warranty is up then after that could go to a 5w30 longlife 3.
With the TDI i would stick with the 0w 30 FS III VW 504 00 / 507 00, and when the warranty is up still stick with it as no need to go to the 5w 30 FS III.
http://opieoils.co.uk
Edited by Ootohere
Thanks for the advice. I’ve ordered the 0w 30
  • 3 months later...
Hi there, have ordered a service kit for my 2015 2.0tdi VRS estate, and it arrived with 0w 30 as is now recommended......The car has been using 5w30 up until now. I had planned on putting Castrol Edge 5w30 LL into the car. But now im wondering is it worth swapping?
Any opinions would be great thank you!
  • 5 weeks later...
The reason manufacturers use 0w oils is to get the fuel consumption down. Hereis something on oils https://youtu.be/zLBgIve1YzY?
There are some interesting results.
  • 4 weeks later...
This oil is not for VAG TDI engines, nothing to compare here.
