Warning lights
Hello all, I’ve had all three of these lights come on at the same time on my 2010 VRS Octavia. Pumped up all tyres and they went off but back on again this morning. Any ideas? Thanks
You have an ABS fault.
All three systems ( ESP, ABS and tyre pressure monitoring) rely on the ABS data.
The only way to know what is bringing up the fault is too read the car with diagnostic tool, as a number of issues can cause an ABS error bringing the lights on.
Ok thanks, I’ll get it in tomorrow to be checked 👍👍
As @softscoop says. FYI this is the second active thread with this issue that I am presently contributing to.
Had exactly same issue. Two rear ABS sensors faulty. Both replaced. Also faulty alternator replaced although not sure if connected.
VCDS will tell you which wheel but you may require a hub/bearing as well as wheel sensor
