How to put the connector back in Driver door
Hi guys
Was just checking the loom to see if any wires were broken that were causing the heated side mirrors to not work...there is but now I can't get the block connecter back in.
Can anyone provide any assistance? Thanks
There may be some plastic tabs that have broken off when you removed the rubber.
It wasn't the rubber I couldn't get in, it was the block connector. I sorted it anyhow, my wife and her dainty hands sorted it. I didn't pull the orange tab far enough back 🤣
While you are hear you don't know the part number or a link for the full loom do you?
  • Sponsor
If you tell me reg number or VIN I can look up loom part number for you, there are a few variants.
PM sent
  • Sponsor
Received and replied.
Your VIN gives part number 5J0971120BC for driver's door loom. Rather scary £158 +VAT from Skoda; you may well find it cheaper even after postage from LLL parts.
Or repair what you've got?
I'm not sure how is go about a repair tbh when it comes to parts swapping I'm competent but with wiring it requires a different skills I'm not good at. Any advice at all? I notice the black/yellow wire had snapped which I believe affects the heated side mirrors. That sound right?
  • Sponsor
There might be more than one black/yellow, did you notice which position on the connector it came from?
What's not working?
From what I saw there were plenty of brown/yellow but black/yellows was one of the thinner ones and only one of that colour type
  • Sponsor
I'll try to look up for you tomorrow. You may need to remind me!
Hero!
