Using OBD2 scanner
Hi All,
          I have a 2023 Karoq Sportline 1.5 TSI and am wondering if the OBD2 scanner can be used to program speed sign recognition and also lane keeping, as I believe I have the camera already fitted as have the matrix headlights. If not will it need the coding done through VCDS, I am thinking of buying the scanner if this is possible.
Thanks in advance
Charlie
VCDS is not the same as a simple OBD2 scanner.
To my knowledge, Carista, Carly or OBDEleven is not capable of coding these functions, but I might be mistaken.
Not sure if this is working, as the post said it needs confirming, but here are the steps for Lane Keeping Assist: #6 (clubskodakaroq.es)
This is the link to enable Traffic Sign Recognition: #10 (clubskodakaroq.es)
You can find many more features that you can enable, however do everything at your own risk.
Before you do any changes to any coding using VCDS, do a full Auto-Scan and save the file securely in order to be able to revert any changes made.
VCDS is fairly smart and makes it very hard to mess up the coding, but sometimes it can happen that you code something badly, and it won't work properly,
@MrSecretPotato
Thanks for the link, having read it I think I may leave well alone and maybe contact someone local who may be able to do this using VCDS, thanks again
Hi @don_kiddik, my one is Karoq Edition 21, for coding I'm using iCar OBD adapter with car scanner app(it was cheapest). It will allow you to play with different things and to scan the faulty codes.
