Columbus MIB3 Nav Maps Update
2 minutes ago, MartiniB said:
in Mk3.FL 2023 Amundsen 8" version date changed after one day,
longest trip were about 90 minutes.
no progress bar and message about finished operation if compare to my previous Mk3 2016 Columbus 8" 😞
updated from OTA loaded 23.12 to Offline 24.06
My still stays on 23.12 after a month. The stick is always in. And the car can see it.
No idea what is happening
  • Replies 85
  • Views 23.5k
  • Hey, a new version of maps have just appeared and MartiniB shared a link for it. The new archive is called OI_P129_EU_202448_Offline_Update and it contains a folder named OI_P129_EU_202448_Offline_Upd
  • Click the bottom option, 'reboot to normal mode' then confirm on the next page
  • I will call them too. I give you an update if I have success on my side
also to mine VIN, and?
I guess I dont understand your previous post then.
This is the latest.
Or what did u mean before?
P119 23.12 is latest published on Škoda's portal
P129 24.06 is latest available for download
open thread i posted above
for me: https://updateportal.skoda-auto.com/en-US/Updates/TMBJW7NP5M7033722
it is 24/25. it is the skoda portal and it is the latest.
It should be published, otherwise I could not download it. Or?
what you linked, I dont know what should I see there
6 hours ago, Shadehand said:
Hi,
My USB Stick is in the slot like a month long now. I see changes in the map ( a main road appeared what was missing earlier), but I guess 1 month is too long for this sheity update. The Map Version is still the old one if I check it.
How long should I wait for this stupid method?
Can Skoda service make any forced update?
Hey!
I tried with a USB Stick Type-C (256GB) and a USB Stick Type-A (64GB) with adaptor to Type-C but maps don't want to update at all for me 😞 I think there is something really wrong with my maps, I had Infotainment Online subscription active for 1 month (trial), and while I could see the other features (busy roads warning sign on certain streets, under construction road sign, etc.), my maps still appear to be 23.6. I am driving on missing roads too, which do not seem to appear even with the Infotainment Online subscription.
From what I had read on other topics, I think Skoda service is able to kind of force update both software version & maps but the Skoda services in Romania can't handle this kind of issues on my car made for Germany.
When I'll move to Germany next year, I hope I'll get to the autohaus from where I bought the car which is also Skoda Plus certified and hopefully, they will help me fix this issue.
1 minute ago, AlexNec said:
Hey!
16 minutes ago, MartiniB said:
Sorry mate, I was totally confused on varsions and skoda site display names.
Pls take my apologies. I downloaded what u linked, and Ill try.
Now it seems I wanted to update the same version what I alrdy have. (but it is wierd why tha main road 83 in hungary was updated :) )
I try the new file and give a feedback.
I'm also experiencing the same issue. Mine is 20.11 and doesn't update OTA and I'm also not able to update through exFat Kingston 64GB USB-C stick...
I've tried following the instructions here:
https://updateportal.skoda-auto.com/Download/Map-updates-mib3.pdf
Downloaded the OI_P119_EU_202425_Offline_Update and followed instructions in the PDF.
(Just now I noticed there is a newer version OI_P129_EU_202448_Offline_Update.zip, will try that one as well)
But just to clarify:
Within the ZIP-file there is one folder containing all the MIB31....-folders.
Should that folder be copied to the root of USB-stick, or should the contents of that folder (all the MIB31....-folders) be copied to the root of the USB-stick?
(As I understand the PDF the contents, not the folder, should be copied to root but as that doesn't seem to work I just want to make sure...)
Edited by PeterSwe
...also: Should there be any indication that update is in progress? I had the USB-stick in the front USB-C connector for 2x1hrs during drive but nothing happens....
Tried also while parking with ignition on.
Really hard to understand this update process....
One information says it's online and autoupdating, another that You should connect to Wifi, a third to do it offline... Really confusing... 🤔
@PeterSwe
Mib3 has no progress bar, my previous Mib2H had
P119 isn't latest, scroll two posts above
You may need a newer version of the MIB3 firmware
The current version is 0330, you can update it yourself
Search it on Google
The new pack what you linked worked like a charm.
It was updated in about an hour. Map version updated.
Lets see if it got any better in hungary :).
Thank you for your support.
Search it on Google
thanks!
I have a really old version. Really disappointed on Skoda reseller and service. Bought the car 2023. I expect them to have updated everything, appearently not. My car is on 270!
So I downloaded 308 and put it on stick.
However for any one else in the same frustration:
I didn't unpack "Meta" and "Data" folders correctly to root of stick and list of devices was empty in engineering mode.
Moving parts of "Meta" folder to root revealed that the car only displays "device" if Meta folder with contents is on root of stick.
So right now I'm unpacking everything to root and retry the update.
Plan is then to upgrade to 330 and finally retry the maps update process...
The latest version is 0332, but I haven't found it yet.
I'm happy to have managed to update to 306 at the moment. Waiting to get 330 and will continue updating...
Maybe this will also solve some other issues like app-car-connectivity, audio droputs etc that Skoda support and service denies all knowledge of 😅
Will it update automatically if not, I can help you, or you have the 0330.
Edited by User_
Thanks, I do have 330, however 306 isn't directly upgradable to it. Need 308 first.... I will do that today, then 330, could have gone directly from 270->308.... 🤪
Edited by PeterSwe
Hey, a new version of maps have just appeared and MartiniB shared a link for it. The new archive is called OI_P129_EU_202448_Offline_Update and it contains a folder named OI_P129_EU_202448_Offline_Update with 710 other files in it.
As per my understanding from the guide, on the USB Stick you should paste the 710 files directly, so these 710 files should NOT be inside the OI_P129_EU_202448_Offline_Update folder in the USB Stick.
Given that when I plug a USB stick int9 the slot under the armrest, can that be used as well to update?
