My black 1.8t L&K
This is a project log for my 1,8t.
Initial Hello post here:
Anyway, after having the car towed back home I wasted no time and scanned it with vcds:
Not much really, just some faulty door locks and errors to do with low battery.
Upon lifting the bonnet i noticed that the battery was recently replaced but not seated right so the cover was not on properly so i corrected this right away:
I checked the oil, and it was overfilled and quite old looking at the colour:
I found some freebies on the back seat, a brake servo pipe and dipstick tube:
So i wasted no time fitting both, the tube that was on the car was in really bad state. I wonder how much of it ended up in the sump...
Servo pipe was also replaced. This is what the old one looked like. I reckon someone damaged it when replacing the air filter..:
This is all the effort I'm going to put into this build thread for now. If there's enough people wanting to see more and commenting I'll  keep going...
Edited by WelshSkoda93
That engine oil is very very new.
On a diesel engine if the oil is not black then its new or not oil at all!
I'm confused now as your profile shows a 1.9 engine hence diesel but the thread title is 1.8 T
In either case the oil is very recent.
Edited by J.R.
I used to own an ALH back in 2018. I've amended it now.
Next were the door locks.
I couldn't get the rear driver side door to open.
I tried sending 12v to the lock actuator through the connector behind the rubber boot but this didn't work.
I managed to open the window by removing all the door card screws I could see and prying the door card off from the top i managed to remove the whole thing without any damage
This allowed me to drill the door lock cog area out, releasing the door:
I then removed the door loom, and inspected it and spliced in new wires where i could see damage and wear.
To top it off i dressed it in corrugated conduit:
And ordered a new lock for it. There's many different listings floating on ebay, i found this 'senco' brand to be the best.
The microswitches in these locks have the additional metal tab and the 'switch' itself is encased in a rubber boot:
Over the next few weeks, I ended up replacing the remaining  3 door locks to the same brand and tidying up the wiring in each door as well.. it was a lot of work.
The car has very little service history, some from 2009 showing it's had a service in Germany, some bits from 2015 and then the new battery in 2023, thats it.
I ordered a whole new complete INA timing belt kit  from autodoc for it which will take ~ 2 weeks to be delivered so in the mean time i focused on ripping out the parrot system and the factory head unit:
Pretty decent rat's nest removed:
Next, a new 2 din android head unit went in. Of course it has android auto and apple car play:
USB ports mounted where the lighter socket used to be:
I 3d printed a little adapter so I can wire in a microphone in the OEM position at the dome light:
And a reverse camera. Feeding the cable through the tailgate was a bit tricky, but went ok in the end:
Camera itself:
Another batch of fixes before the MOT:
There was an intermittent code for SAI system. I read about it and just ordered a whole new set.
I removed the old SAI pipework and found a split here:
Other components just crumbled in my hands when I removed them. I thought about coding the SAI system out for about £150 at a local tuner, but it was around £80 to have it all fixed so i opted for that.
Even though i used part numbers from ETKA the sai asembly wasn't a complete match to what's on the car, but i managed to piece together one good assembly combining used and new parts..
This is from MaxGear:
This is from Topran:
I also replaced all the piping going to and from the SAI pump but forgot to take pics.
The last thing before the MOT i tackled was the radiator fan. It was seized.
I ordered a new fan from Maxgear:
It was an absolute nightmare to replace it as 1 out of 3 bolts holding the old one have snapped due to rust so i had to use a traditional nut and bolt instead:
Got there in the end:
At this point i felt the car was ready to scrape by on the MOT.
I asked for a new set of tyres to be put on beforehand, These were the closest Firestones I could find to the release OEM tyres:
The car passed with some advisories:
I agree about the Macpherson bushes and rear springs.
This will get done.
Not so much about the 'defective exhaust mount' This bracket on the exhaust simply isn't used on the Octavia..:
Corrosion on sills is also questionable, but there nonetheless:
Rear spring:
More to follow... I'm just getting started.
could be a faulty voltage control relay to the ecu
Few odd jobs:
Got a nasty leak in front passenger footwell, narrowed it down to a missing grommet in the cabin air filter area:
I found a suitable grommet, added some dirko sealant just to be sure and plugged the hole. The damage has already been done though, I'll have to strip the interior and replace the carpet and sound proofing:
Next thing was a super rusty PS hose:
Autodoc came to the rescue with an affordable febi part, i had to source the 4x copper washers separately though:
Rear wiper wasn't spraying, I remembered back in 2018 my first octavia had the same fault and the union behind the boot liner roughly in the cd changer area has come apart. I've plugged it back in and put a self adhesive heatshrink over it so it won't happen again:
Oil cap did't feel tight and was slowly leaking, so i replaced the seal on it as well:
Fuel cap has also seen better days so it was replaced with a TPS part:
Same for the antenna:
Arm rest latch as also been fixed with a cheap ebay parts:
The car came with 2 key fobs. both not working remotely.
First one was an easy fix, just replacement of the battery, the second one was not.
It was missing the battery terminal so i bought a 'blank' on ebay and replaced it, its still not working.. not sure what im going to do about it.
Some more stuff from TPS, because autodoc is taking a while to deliver my timing belt stuff....
2x front badges
2x air filter screws
1x fuel filler cap (seen in earlier pic)
Replacing the badges was very satisfying:
Next came the service.
New plugs, fuel filter, oil, oil filter, cabin air filter, coolant and Ps fluid.
Looking at this stuff, the car has not been maintained properly for years:
The sump plug has of course been tightened with an impact and not to 15nm so i changed the oil but knew I'll have to do it again soon as 1. it was leaking out through the shredded thread of the sump bolt and 2. I was going to do it anyway as a form of a flush....
New sump and gasket. I decided to use a gasket as i would be doing this on a friends lift and didn't have to wait for it to cure:
Old sump out. Lots of bits of the old dipstick tube..:
Intake tube also full of junk including a full length rubber band.. This was removed, cleaned and put back on the car:
New shiny sump back on. It was a bit of a pain to install the 3 bolts going through the gearbox bell housing due to the thickness of the gasket, but with some persuasion it all went in:
It survived a 100 mile trip back home with no leaks, all good.
I got bored of all this maintenance work so I went shopping...
Old spark plugs are old.
where did you find the sump with gasket?
I got them separately.
Gasket: 06A103609C
Sump: 038103603M
Progress has been slow, i fixed all the door leaks + the lhd bonnet release grommet as in previous post but carpet was still moist, i ripped the whole interior out to see where it was coming from and it turned out to be the rhd bonnet release grommet and the electrical box cover...
I cleaned the scuttle panel area up, cleaned both the electrical box and cable grommet and reinstalled both using windscreen adhesive.
If they both leak again, ill buy a new lid and replace the cable grommet with a cable gland...
I also realised that  you can have a leak at the rear footwell even though the actual the leak is coming from the front because of the way the floor pan is built, it just allows water to travel all the way to the back.
I created little 'dams' with windscreen adhesive to stop the leak spreading if it ever happens again:
Finally, i threw all of the factory sound proofing and carpets away. I left the car for a few days in Welsh rain and wind and came back, it was all dry.
I proceeded with installing 30 2.3mm thick bitumen mats on the floor pan:
I will then use carpet underlay and layer as much of it as i can before fitting the main carpet.
The eagle eyed of you will spot i also removed my android head unit and installed an MFD1... more on that later.
I found the HVAC ducting split:
So i fixed it up with some rivets and my favorite windscreen adhesive:
I really didn't like how it all went it, there was no satisfying click sound, so I've put in a spreader river for good measure:
I've re-assembled the cut up pieces of original sound proofing and replaced the 'missing' bits with 2 layers of 12mm carpet underlay.
Having to leaks in the car and no wet sound proofing has completely transformer the way the car smells and i feel much better being in it...
some time spent so far , mine condensates but carpets feel dry and clean , may check the boot area lol
Edited by dubDEAN
Finally had some time to spend on the car:
Replaced driver side undertray cover and installed diesel automatic undertray.
These were brand new pattern parts and if i was to do this again I would buy good second had parts. Fitment was 'challenging' to say the least:
Also replaced these L brackets which hold up the front of the bumper, I've seen these broken on almost every single octavia ever:
Last but not least... working reverse camera with automatic switching to rear view:
ASR and Windscreen buttons will be corrected.
This is how i  waterproofed all of my doors.
1.First of all all the original foil removed, glue residue removed with label remover.
2. First layer of foil applied with the bottom part put inside the door, so that any rain water flows into the door and out through the holes as it should:
3. I then applied a second layer of foil just like the original stuff, using butyl tape to seal it. Notice how i used a single piece of it and routed it above the threaded door card clips:
4. For the front doors I also replaced the standard plastic threaded inserts for speakers with rivnuts, clamping the foil with them as well so it all became very water tight.
With the above approach I've been able to permanently stop water getting onto the sills and leaking inside.
a job i must do ,as hate wet sills when car washing
I got myself a transporter wiper arm and golf mk4 wiper motor.
Motor fits fine, but the arm requires some adjustment:
I sanded down probably ~1cm from the bottom of the arm:
And now it fits:
A job for tomorrow will be this, a very common fault. I'll probably go over to screwfix and get some tube crimps:
