Timing Belt Change Interval
Good Morning
After the success of my fabia sailing through the MOT with just a cracking tyre advisory (which has now been changed), I thought I would give her a full service as its coming up to 12 months since the last one. I noticed in the service book that its been 6 years since the last timing belt change, but the car has only done about 10,000 miles in this time. Coming from Vauxhalls, the change interval was every 80,000 miles or 8 years, but researching the Fabia gives conflicting results of 40,000 or 4 years, or 60,000 or 5 years.
Is there a reason the age interval is so low for the fabia compared to other car manufacturers? Is it safe to keep driving on a 6 year old belt for a couple months even if its only done 10k?
  • Sponsor
Have a look at the belts by removing the top cover, but I doubt you'll see anything worrying.
I wouldn't bother if I were you, those belts and associated bits will be good for a lot longer. Did the water pump get changed last time?
Would you do the work yourself if you did change it? (Changes the economics of it greatly).
Edited by Breezy_Pete
I did have a look at it when I was tinkering this weekend and it looked okay. Water pump and aux belt was changed at the same time as the timing belt back in 2018, so hopefully they have a good bit of life left in them. I'll probably look to change them in the new year though for piece of mind and when I have some extra cash.
I probably wouldn't do the belt change myself. I'm good with general servicing but my last belt change I did myself (on a Vectra) didn't go so well so I would rather know its been done properly as this car is not only my weekend car but also my partners main car so I can't break it.
