Child lock error on replacement door lock
I replaced a rear door lock on my 2018 Superb L&K, and now the electronic child lock is permanently engaged. An error is displayed on the dashboard if I press the button to disengage the child lock.
Does the car need to be re-programmed to accept the new lock, or did I buy a lock without the electronic lock facility?
What was wrong with the old one?
Did you buy a new or used part?
Was it genuine or aftermarket?
Was the part number compared to the old one?
Have the fault codes been cleared?
Has the live data been checked?
Sorry for the late reply - I've been away.
What was wrong with the old one? - It wouldn't lock.
Did you buy a new or used part? - New
Was it genuine or aftermarket? - aftermarket
Was the part number compared to the old one? - I don't remember.
Have the fault codes been cleared? - No
Has the live data been checked? - I don't understand
Have you got the link to the one you purchased?
and have you got your vin number, ill check if you ordered the correct one.
On 13/10/2024 at 16:21, Michaeljo said:
Hi - thanks for your reply.
This is the one I bought: https://www.autodoc.co.uk/spares-search?keyword=VEMO+V10-85-2281+Door+lock
VIN: TMBBD7NPXJ7570916
So the link you provided has the following compatible part numbers: - It also doesnt have the child lock function - safelock is something else.
OE 5E0839016 — VW
OE 5K0837350B — VW
OE 5TA 839 016 K — VW
OE 5E0839016B — VW
OE 5TA 839 016 P — VW
OE 5G4839016 — VW
OE 5G4839016C — VW
OE 5NA839016 — VW
OE 5NA839016B — VW
OE 5NA839016D — VW
OE 5TA 839 016 D — VW / AUDI / SKODA / SEAT / VAG
Whereas the parts catalogue for your car lists the following as compatible for the rear right:
5TA839016H
5TA839016N
5TA839016T
So id say that it is the incorrect part, but fault codes will also need clearing after replacing it with the correct one.
5TA839016H
5TA839016N
5TA839016T
Thanks, that's very helpful. I wonder what the differences are between the three parts you listed as compatible?
No difference, just newer revisions of the same part.
Ive listed them oldest to newest for you
This one's part number is A6T-5TA 839 01 6T.
Do you reckon this is the right for my car? It's half the price of a new one.
Spot on, that will work perfectly
being from a 2021 onwards car means it’s fairly new still so I’d get that at half the price of new.
I've bought that one.
Thanks for all your advice.
  • 3 months later...
I too have an error message, “electronic child lock” when turning ignition on, I had rear left door lock replaced after the door wouldn’t open from inside, new lock works fine but error or warning flashes up on dash, car is a 2022 superb 1.5 tsi hatchback and the new part number is 5TA-839-015-T Genuine part from
 TPS, all faults cleared but error still there and no faults showing up on scan, any ideas please
Did they fit the correct version for your car? The one you have looks like the basic one without the child lock motor. I made the same mistake. The basic one was about €70.00, the correct one was € 240.00 !
I don’t know, I paid £250 for it, I gave the TPS the registration number when ordering it, I’ll check with mechanic if part numbers match
The problem seems to have sorted itself out after using the door switch to activate and deactivate the child locks a few times, so maybe it’s reset itself.  Here’s for input it’s much appreciated
