No drive mode change by mode switch
Three months ago I bought a Skoda Superb iii tdi used car in which the problem is that after pressing the drive mode button, no option appears on the screen for selection like eco, normal, support... and no gear stick position light illuminates ઓન (P R N D) the gear panel. No but sport mode and normal mode can be changed through gear shift stick and normal driving is happening, please let me know if there is any solution, I have the vcds, if there is any coding or activation, let me know, I will be very grateful.
You first need to check for any fault codes and also the live data of the button itself to see if it’s working.
if the button is seen to work by the bcm, then the issue falls to either swap codes or incorrect dataset on the gateway.
is this factory fitted or an attempted retrofit?
It's factory fited ,there is no code checked by vcds
