Superb question
Hello
question
I will buy a superb 2021 with 2.0 tdi 147kw/200hp engine.
It has 147000km on cluster.
Does this engines stil have problems with watter pumps?  It says big service is on 210000 km…  is this engine good or is there anny problems? Also how is DSG in this cars?
manny thanx
Hello, are you sure of your engine specs - has the engine been modified in this car?
Hello
On website  says 147kw  200hp. Original engine. Superb is 4x4.
its is 6.2021
Thats all i know
How are this dsg dq381? Safe to buy?
Edited by Seba800
That should be the last version with the 4x4.
I think the water pump problem never went away.
The 381 boxes have some issues, look at the topic in this section.
Ideally, you should have a full service history on these cars.
Thank you
What do you think?  Good to buy? Dsg services has ben made At 60000 and at 120000km.
And if i buy i must do a big service right? Becous stupid water pump :)
Well, mine is a benzin, I decided to "watch" the level of the coolant and underneath the car once in a while ... if I see signs of dropping level or losing, will address the pump matter.
Same for the DSG, there are no guarantees of how, or how long it will last...
If you like the car, go for it. For sure you need always a good service/workshop to address any issues.
Hello
Dsg DQ381 Dont have service intervals on 60000km?  Its says 120000km??  Is this correct?
I do not know where you are, so you should check the intervals for your country.
Here they give it at 80k km, but I arranged to have it done earlier, at 60k.
And how are this engines? 147kw 200hp?  Hawe some problems or are ok?
I have a petrol/benzin, do not know about Diesels. But are plenty information in here 🙂
Does anyone have the settings for 0044 power steering settings of skoda superb 2.0 tdi.
Driver profile selection:- active/not active
Characteristic curve of steering assistance.
1.driving profile selection button
2.comfort
3.Dynamic
4.Automatic
5.default
Which one is the correct settings by default on stock skoda superb 2017.
Are the problems on dsg dq381 with mehatronic problems being solved on 2021 superb 147kw?
Thank you
Thank you
Should be solved after 2020, but who knows.. recently I changed both sensors on mechatronic 11/2018 production date
