OBDeleven for VAG - updated for Octavia MKIV FL
A new OBDeleven for VAG update has been released (iOS 1.9.46) which allows SFD2 to be read/write.
You need to set up 2FA on the app with something like Google Authenticator, MS Authenticator etc. and verify a few details.
I've not had chance to really dig into it but it can read all modules, show any fault codes and clear them.
thanks just updated
Have you been able to do any coding of a module where no fault code has been found in? I can only access details in module 19, which is the only one it has found a fault code in. I have facelift sport line and every time I try to access any other modules it asks me to check ignition cause the control module does not respond. Tried with hood open, activated 2FA. Just bought the OBDeleven and saw a way to deactivate speed warning, but I can’t even access the module A5.
Any ideas?
Is there a changelog for this? I’ve been wanting to do eeprom/dataset writes on the 5F and hoping this helps…
Any ideas?
I successfully managed to get past my issues by uninstalling the app and re-installing it. Now I'm able to long code and have already been able to disable speed limit warning in unit A5! If only there were now a way to adjust Carplay to higher resolution to fit more information on the screen, just like it were on the previous 2021 Octavia. I really hate these large "old people" icons and I wish they could add a setting for it.
