Boost Actuator voltage
Hi all, does anyone know what the max and minimum  voltage range is for the boost actuator on a 1.6 CLHA engine. Many thanks just want to check it’s adjusted correctly as still get P2564 after changing the actuator.
Daffy question - did you replace it with a proper OEM or good quality product?
Yes, they have a fixed rod but slight movement with the elongated fixing holes.
