Rear Internal Cabin Lights are illuminated all the time
Since getting my car back from my local Skoda garage (tailgate problem) the two rear inside lights in the cabin are permanently lit. When I press the button on each of the lights it does nothing. The lights only go out when I turn off the ignition. Is this an easy fix using the ODB app Carista (which I have) or within the infotainment menus, or do I have to take the car back to the dealers? Thanks.
There should be a switch on the roof consul for turning rear lights on/ off.
I tried everything on the front roof console but nothing seemed to turn out the rear cabin lights. Do you know what the actual switch looks like?
Thank you, I'll try this in the morning.
May also be worth you reading the manual as all explained there
There's a switch on the roof console that doesn't actually switch the lights off but when pressed allows the rear light swiches to work, so it's a two stage operation!
Thanks RodDuggan, I have now figured it out and have now turned off the lights in the rear of the cabin.
Edited by FabFabFabia
