Need a part number for under the hood grommet/bung.
Hello fellow Škoda owners!
The thing I need is actually quite easy, only I don't have the parts numbers. I supplied the picture (found online) with pointing arrows for easier explanation. Those two rubber grommets in the corners of the engine bay and a clamp/clip for what is, I presume, air temperature sensor (I just want to make sure that I order the right clamp because I see many similar online). If not evident, the car is Fabia Mk1 1.9SDi.
Cheers.
Not sure of clamp but I use blank electrical grommets instead of plugs if I can get the right size. You might be able to find them on https://skoda.7zap.com/en/cz/
Alasdair
