TDI CR170 Lumpy start
I have had my 2012 VRS tdi for 2 months now and on cold mornings it is starting a bit lumpy.
I have noticed the glow plug light quickly goes off when I turn the ignition on and then when I fire the car up it stays on for 5-10 seconds solidly. It's not flashing. The car runs lumpy for 10 seconds and then settles.
No codes on VCDS.
I have tried ignition on and off a couple of times, doesn't seem to make a difference.
It cranks slowly if I leave the car standing for a couple of days in the cold.
Could it be the battery? Is there anything else I can check in VCDS?
Ok, this is critical. Do you put your seatbelt on after the ignition and before keying the starter?
Nope never.
I always jump in, turn it on and then get out of the car and load the boot up.
Edited by bluevrsman
36 minutes ago, bluevrsman said:
Nope never.
Ah, it will start better if you switch on, put your seatbelt on, and then key the starter.
That's crazy. I'll give it a go.
So the seatbelt is a pre-req for the glow plugs?
I thought on the CR engines as soon as you unlocked the doors the plugs started to heat up if the outdoor temp was below a certain threshold?
Ah, you misunderstand. The seatbelt is to give the glowplugs a few seconds before you key the ignition. It may not work, but at least it's free.
Oh I see what you mean now😁
I have left it for 10 seconds. Ignition off. 10 seconds back on, fire it up, car shakes a little.
Will a VCDS check show all glow plug faults ? My previous diesel octavia would start rough if i cranked it before the glow plug light went out.
