2011 VRS, no power. very slow
Hi
Bought a 2011 VRS with possible turbo and other problems
We went through faults, replaced faulty turbo diverter valve, cam sensor and checked operation of turbo actuator
CEL turned off, but cars very slow. 0-60 times of 14 seconds. car does rev out but serious lacking grunt
Any common problems to reduce power?
Turbo pressure on full throttle, high revs shows -2.3psi
Billy
It sounds like it's stuck in limp home mode, how are you reading the faults?
Very possibly the Supercharger is disabled.
Water pump / Supercharger Clutch.
It should be coming in at 2,800 - 3,500 rpm with the Turbo and no turbo from 3,500 rpm.
IIRC, relative boost should be around 1.5bar (22psi)
Edited by Warrior193
correction, misread heading.
Sounds like it has a massive boost leak , should be boosting over 1.0 bar of boost on stock map , check for hole in intercooler / smoke test it
Check intake hoses (to from charge cooler) I've had one come loose and it presents those symptoms
With obd link Bluetooth scanner
How do I test ? There is plenty of low down power , does the supercharger make some slight noise anyway ?
Easy to see these hoses and joints or is it bumper off job? Thanks
Thanks all of you and sorry for late replies
@Cubbs Did you get a resolution to your problem?
Hi. Jo not yet not had a chance. I removed turbo heat shield and checked actuator rod moves and there’s no play
You any ideas ?
