DSG P2797 Fault Code
Evening all,
I spotted the dreaded "Error Gearbox" message on the maxidot this morning and it popped up again this evening. Only lasted about 2 seconds and then it was gone.
I did a VCDS scan when I got home and it showed the following:
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 042 F HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1621
Revision: 00005006 Serial number: CU501605075559 CVN: B5A4E042
Coding: 0014
Shop #: WSC 33361 790 00063
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021.rod
VCID: 392F255109DA299250D-806C
1 Fault Found:
38526 - Control Circuit for Auxiliary Transmission Fluid Pump
P2797 00 [00101100] - Implausible Signal
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 317501 km
Date: 2025.03.14
Time: 07:57:29
Engine RPM: 2569.75 /min
Engine torque: -72 Nm
Vehicle speed: 86 km/h
Control Module temperature: 48 °C
CURRENT pressure: -6.0 bar
Driving position: Malfunction
Accelerator pedal position: 0.0 %
DTC memory status: 39424
I did a bit of googling and it seems to point toward one or more of the Mechatronic solenoids could be sticking or is becoming briefly inoperative.
Has anyone ever had this code pop up and if so, what was the diagnosis/fix?
I have long suspected one or more of the solenoids may be defective which is why the gear changes are so lazy and not as "snappy" as I'd like them to be.
I found this description on the web. Just wondering if there is also a Transmission Fluid Pump 'B' ?
P2797 Code Definition
P2797 Electric/Auxiliary Transmission Fluid Pump 'A' Performance/Stuck Off
What Does the Engine Code P2797 Mean?
Character "P" in the first position of Diagnostic Trouble Code (DTC) represents the powertrain system (engine and transmission), "2" in the second position means that this is a ISO/SAE controlled OBD-II (OBD2) DTC. "7" in the third character position in a DTC indicates that the transmission is experiencing a malfunction. The last two characters "97" is DTC number. OBD2 Diagnostic Trouble Code P2797 means that Electric/Auxiliary Transmission Fluid Pump 'A' Performance/Stuck Off has been detected.
