Octavia III, 2.0 Tdi - is making a strange clinking sound coming from somewhere around the exhaust system
Hi,
I’d like to kindly ask for your help with this issue. My Octavia 2.0 TDI 110 kW is making a strange clinking sound coming from somewhere around the exhaust system. I tried to capture it on video, which you can find at this link: https://drive.google.com/file/d/1U8YQ8knldjYuLvzh2yBrkacl3si0e99H/view?usp=sharing
Would anyone happen to know what might be causing this? There are no error messages showing up. The car has around 100,000 km on it.
Thanks in advance for any response.
Loose baffles in a silencer?
Thanks for the tip! I'm not a professional or very experienced — is there an easy way to check this baffles ? Thank you
With the exhaust cold get underneath the car and tap the silencer(s) and DPF.
  • 4 months later...
I found what makes that sound. It’s the part in the picture. It seems to be some kind of flap or something like that. I guess it’s part of the AdBlue system, but I’m not sure. Does anyone know what it is?
I noticed that it doesn’t fully close or open. Instead, it makes a clicking/rattling sound, which seems to come from the flap moving. When I gently touch it by hand, the whole thing shifts a little and the exhaust sound becomes quieter. Normally, my exhaust is constantly hissing — similar to the sound when the DPF is regenerating.
So, the rattling sound and the hissing from the exhaust are caused by this part that doesn’t fully open or close. Does anyone know what it is and what I can do about it?
  • 7 months later...
Hi, did you find the solution? Jli have the same problem.
