Skoda Superb 3 - Infotainment problem after using old version of VCDS 12.12.3.0
I tried to activate the Off-road menu on a Skoda Superb 3 model 2018 using VCDS 12.12.3.0 (I was not aware of the problems with coding with older versions of VCDS.
Currently it is reporting an SOS call error and an error in the Telematics module. The LED on the SOS button is green and the SOS calls are functional.
Can you advise me how to get rid of this error?
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0
Data version: 20140905
Address 75: Telematics (J949) Labels: None
Part No SW: 5NA 035 284 B HW: 5NA 035 284 B
Component: OCULowMQBLGE H17 0718
Revision: --------
Coding: 03840101EA423A0D3B1C9E000045400382E608
Shop #: WSC 33361 790 00123
ASAM Dataset: EV_OCULowMQBLGE 004044
ROD: N/A
VCID: 3C7142ABB7E975FE875-8069
No ASAM data for: "EV_OCULowMQBLGE" (VW36)
1 Fault Found:
0053 - ROD - Unknown Error Code
- 00 [009]
Confirmed - Tested Since Memory Clear
Are you 100% sure that the VCDS is genuine? 12.12.3.0 is 13 years old which is very strange as updates to VCDS are free.
Did the VCDS cable come with software on a CD? If so then that's a very good clue that what you have is a pirated clone.
28 minutes ago, PetrolDave said:
Si si 100% istý, že VCDS je originálny.....
I don't know, I had a borrowed laptop and a cable. I didn't know I couldn't use the old version. I thought that when it loaded the module and showed me the adaptations, it was ok. Only then did I read here on the forum that there were problems with older versions. Now I have version 25.3 and a HEX-V2 cable.
Edited by Hennrok69
Maybe post a full autoscan from your legit HEX-V2 and the latest 25.3 VCDS version... It will probably give more information.
Chassis Type NP-SK48 (3Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 2B 36 3C 42 44 47 4B 52
5F 69 6C 6D 75 A5 BB BC CA
VIN:
Mileage:
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 ES HW: 04L 907 309 R
Component: R4 2.0l TDI H24 1989
Revision: B5H24--- CVN: 7FCF0AFE
Coding: 01190012045405083000
Shop #: WSC 09438 004 1048576
ASAM Dataset: EV_ECM20TDI01104L906026ES 002002
ROD: EV_ECM20TDI01104L906026FK.rod
VCID: 7F0DB6FBE6FD7563B9-802A
VINID: 91D4916097A0A1A1C50C71481807543852
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CG HW: 5Q0 614 517 AG
Component: ESC H62 0643
Revision: 00000000 Serial number: 62677000003034
Coding: 1D076A9C34230B73477C060840C949B8562CD0E2600292753463F0F8C0A2420000000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
ROD: EV_Brake1UDSContiMK100IPB_036_VW37.rod
VCID: 78FF5DE7C3D3425BF8-802C
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0906
Revision: 00037000 Serial number: 0452028572 Dataset Number: V03935254SK 0001
Coding: 032C0C060F
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_KessyHellaMQBAB 004041
ROD: EV_KessyHellaMQBAB_004_VW37.rod
VCID: 3E738BFFA177BC6BF2-806A
Rear lid opener control module:
Subsystem 1 - Part No SW: 3AA 962 243 G HW: 3AA 962 243 G
Component: GEB.F.Heckoef H16 0903
Serial number: 84530588
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 3V0 907 044 CM HW: 3V0 907 044 CM
Component: AC Automat H34 4402
Revision: 20K10000 Serial number: 00000B00677784 Dataset Number: 0000
Coding: 1101010400211001100510000010112A
ASAM Dataset: EV_ACClimaPrehVW37X 002025
ROD: EV_ACClimaPrehVW37X_002_VW37.rod
VCID: 0109300390090393CF-8054
Humidity sensor: exterior:
Rear air conditioning block 1:
Subsystem 2 - Part No SW: 3V0 907 049 E HW: 3V0 907 049 E
Component: E265KlimaHeck H02 0101
Serial number: 06051501850797
Coding: 000000
1 Fault Found:
263425 - Air Quality Sensor
B10AF 04 [00001001] - Internal System Fault
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 150
Mileage: 98805 km
Date: 2025.04.25
Time: 10:08:58
Outside temperature: 19.0 癈
Voltage terminal 30: 11.9 V
System run time-Engine running time: 0 s
System run time-Terminal 15 on: 253 s
Air quality status: Malfunction
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 CQ HW: 5Q0 937 084 CG
Component: BCM MQBAB H H36 0253
Serial number: 01001728001689 Dataset Number: V03935274XS 0001
Coding: 000000000000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_BCMMQB 018001
ROD: EV_BCMBOSCH_018.rod
VCID: 09192823A8394BD397-805C
Wiper motor control module:
Subsystem 1 - Part No SW: 3V1 955 119 HW: 3V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: 48x LL 170906 032 0121
Serial number: 00000001709040303935
Coding: 164DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 047 0105
Serial number: S8Y17M10D04H03M36S08
Coding: 00084D
Anti-theft alarm system sensor:
Subsystem 3 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY1724525L3
Alarm horn:
Subsystem 4 - Part No SW: 5QD 951 605 HW: 5QD 951 605
Component: Sirene, DWA 005 0314
Serial number: 00002856223972473207
Blower 1 for left front backrest:
Subsystem 5 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0101
Serial number: ESE0348681
Blower 1 for left front seat cushion:
Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0299210
Blower 1 for right front backrest:
Subsystem 7 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0298787
Blower 1 for right front seat cushion:
Subsystem 8 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0828283
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Component: PDC 8 KanalH07 0044
Serial number: 000308418617273 Dataset Number: V03935262KV 0001
Coding: 0471155941
ASAM Dataset: EV_EPHVA18AU3700000 009035
ROD: EV_EPHVA18AU3700000_009_AU37.rod
VCID: 4B95D22BE2C519C365-801E
Address 13: Auto Dist. Reg (J428) Labels:. 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 R HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0771
Dataset Number: V12345678AA V305
Coding: 2A057FCA59FFC728949F81B463470700000000000099000002
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_ACCBOSCHVW416 003014
ROD: EV_ACCBOSCHVW416_003_VW41.rod
VCID: 4683E31FF9A7E4ABBA-8012
No ASAM data for: "EV_ACCBOSCHVW416" (SK48)
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0121
Serial number: 12091741350006 Dataset Number: V03935252TY 0001
ASAM Dataset: EV_DRCONTITEMIC 001019
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 387F9DE78353825B38-806C
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 BK HW: 5Q0 959 655 BK
Component: AirbagVW21 005 0336
Serial number: 003VXR3CFZD0 Dataset Number: V03935255BD 0001
Coding: 98FCC0C0000000005C5400CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002158
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 0A1B172FAD3F40CB9E-805E
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 000 210 17
Component: SideSensor_Df 001 0887
Serial number: 35700000000923816629
Coding: 2D2D2D
Crash sensor for side airbag: passenger side:
Subsystem 2 - Part No SW: ----------- HW: 480 000 210 17
Component: SideSensor_Pf 001 0887
Serial number: 3580000000089C79962Z
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: ----------- HW: 480 400 610 17
Component: SideSensor_Dr 000 6149
Serial number: 3510001C9267FA34013$
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: ----------- HW: 480 400 510 17
Component: SideSensor_Pr 000 6149
Serial number: 3520001C1267FA3445F9
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 400 510 17
Component: FrontSensor_D 000 6149
Serial number: 3550001C5267FA318445
Coding: 2D2D2D
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 GE HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF035035 Serial number: 20171004501181 Dataset Number: V03935265ZH 0001
Coding: 6404
ASAM Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 7BF542EBF2E5694395-802E
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 3V0 920 790 A HW: 3V0 920 790 A
Component: KOMBI 507 1691
Coding: 05A501127F8C0008018B730B5001000880000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001026
ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
VCID: 356194D394417F3323-8060
1 Fault Found:
1246804 - Expanded Bus Activity Active
U1104 00 [00001001] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 150
Mileage: 98805 km
Date: 2025.04.25
Time: 10:11:11
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 30091710523541 Dataset Number: V03935258RY 0001
Coding: 030100345F087300CB0002DA880F00010001070000000000000000000000
GVL: 01563C0008000600C0DC800080024C0010000000000200000000000000000000
ASAM Dataset: EV_GatewNF 013023
ROD: EV_GatewNF_VW37.rod
VCID: 3365AACB9A3561030D-8066
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A
Component: E221__MFL-PR6 H02 0160
Serial number: 000000000C1626041017
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H10 9070
Serial number: 9286685304
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 17000266030017
ASAM Dataset: EV_ELVMarquMQBB 001007
ROD: EV_ELVMarquMQBB_VW41.rod
VCID: 71E960C3A0A913133F-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Component: Sitzmemory H08 0022
Serial number: Y0006QIS12412
Coding: 0010000200000500018280808080000000008181000000D400
Shop #: WSC 85145 916 91614
ASAM Dataset: EV_SeatMemorDriveSide 002021
ROD: EV_SeatMemorDriveSide_002_VW48.rod
VCID: 3C7781F7B76BAE7BDC-8068
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0080
Serial number: 0456351911 Dataset Number: V03935251FB 0001
Coding: 02012103
ASAM Dataset: EV_HREntryHella 001028
ROD: EV_HREntryHella_SK48.rod
VCID: 3D718CF3AC71A773EB-8068
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0080
Serial number: 0455934736
Coding: 020121
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 0000281492008 Dataset Number: V03935256LS 0001
Coding: 001D0820DE00040000001100
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
VCID: 479DEE1BFEADFDA341-8012
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2051
Revision: 00000000 Serial number: 0002052004 Dataset Number: V03935255ZZ 0001
Coding: 01000011004001
ASAM Dataset: EV_SteerAssisVWBSMQBA 009129
ROD: EV_SteerAssisVWBSMQBA_009.rod
VCID: 408FF507DB83CA9B80-8014
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 223 HW: 81A 035 223
Component: MIB2_amp_P_SK H10 0410
Revision: 00000001 Serial number: SKZ8Z1HJE02VTBZ Dataset Number: V03935263JW 0001
Coding: 0384010000AA002FAA0000000000
ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001
ROD: EV_AMPMst16C5Gen2ALPI.rod
VCID: 59B9386358197B53E7-800C
Address 4B: Multifunc. Module
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 0000282133528 Dataset Number: V03935256LW 0001
Coding: 001D0220DE00040000001100
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 565 035 043 E HW: 565 035 043
Component: MU-H-N-EU H54 1440
Serial number: A856I0HS013590 Dataset Number: V03935357Z 0001
Coding: 03840101000000005111000200000A002F0103E4012004009E
ASAM Dataset: EV_MUHig4CGen2HBAS 001001
ROD: EV_MUHig4CGen2HBAS_AU37.rod
VCID: 14270957FF7B863B74-8040
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 3V0 919 606 D HW: 3V0 919 606 D
Component: ABT_High-2 H50 9130
Serial number: SKZ6ZHT2713013
Data carrier:
Subsystem 2 - Part No SW: V03 959 821 AR HW: -----------
Component: ECE 2025 --- 0390
Serial number: --------------------
Compact disc data bank:
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1016
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 H HW: 5Q0 907 383 C
Component: Anhaenger H21 0204
Revision: 8B001003 Serial number: 0407210344 Dataset Number: V03935247XH 0001
Coding: 0100000202000000
ASAM Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_VW37.rod
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H12 0231
Dataset Number: V03935246QD 0001
Coding: 0484010183002017000040
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB.rod
VCID: 397998E3B8599B53C7-806C
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 L HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0261
Revision: -------- Serial number: 31584694000000 Dataset Number: V03935263DB 0001
Coding: 1088
ASAM Dataset: EV_DeckLidCONTIAU736 001014
ROD: EV_DeckLidCONTIAU736_VW37.rod
VCID: 4189F003D089C3938F-8014
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Revision: -------- Dataset Number: V03935265GS 0001
ROD: EV_OCULowMQBLGE_004_VW25.rod
1 Fault Found:
0053 - Databus
U1121 00 [00001001] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 150
Mileage: 98805 km
Date: 2025.04.25
Time: 10:14:42
Voltage terminal 30: 11.8 V
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3QD 980 654 HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 1272
Serial number: 11091741K10147 Dataset Number: V08154711FU 0001
Coding: 0204080100000401002223558150A90094000E100040
ASAM Dataset: EV_MFKBoschMQBB 001001
ROD: EV_MFKBoschMQBB_001_VW36.rod
VCID: 081F2D27B33332DB88-805C
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q4 959 395 E HW: 5Q4 959 395 B
Component: TSG HFS 012 0032
Serial number: 0000280090331 Dataset Number: V03935256ME 0001
Coding: 001C00208000040000001100
ASAM Dataset: EV_DCURearDriveMAXCONT 006001
ROD: EV_DCURearDriveMAXKLO.rod
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 012 0032
Serial number: 0000280629185 Dataset Number: V03935256MK 0001
ASAM Dataset: EV_DCURearPasseMAXCONT 006001
ROD: EV_DCURearPasseMAXKLO.rod
Address CA: Sunroof
End-------------------------(Elapsed Time: 06:19)--------------------------
------------------------------3 Faults Found-------------------------------
Edited by Hennrok69
Based on "Please upgrade to a current Ross-Tech interface." and "[New feature! Extended UDS fault detail is only supported by current gen. interfaces]" I'm afraid to say that is not a genuine Hex-V2...
Was it made with 25.3 as requested? The header wasn't posted and I'm no expert at spotted the output of hacked versions of VCDS so it's not clear to me.
20 minutes ago, PetrolDave said:
Bolo to vytvorené s verziou 25.3, ako bolo požadované? Hlavička nebola zverejnená a nie som odborník na rozpoznávanie výstupu hacknutých verzií VCDS, takže mi to nie je jasné.
yes, ver. 25.3
Friday,25,April,2025,10:25:07:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 25.3.0.3
Data version: 20250301 DS365.0
www.Ross-Tech.com
Edited by Hennrok69
