Posted
As the title suggests troops. is the above compatible with an OBDII code reader?
Your help with this detail will be appreciated.
Cheers.
IainGill.
Thanks AP, much appreciated. 40.5 avg mpg?? Did you find a /gearbox design engineer at VW who managed to supply you with a higher 5th gear, if so give me his/ her name & number. It revs its heart out in top at 3000 rpm. A drop to 2800 to supply same top-end would be beneficial. Have a good day, once again thanks for your help... IainGill.
Same gearing as yours! Desperately needed either an extra gear or a better fifth. You acclimatise eventually...
There was a sixth gear upgrade for the 1.9TDi PD100 box. Bit pricey so I never sorted it on mine.
you can swap out the fifth gear cogs for longer ones, like 02T 311 361 AB, 02T 311 158 AT ones with 0,673 ratio. this info is right for my 1.4 16v fabia with MQ200 gearbox, not sure if it applies to 1.2.
