Heated seat replacement / retrofit with universal part?
Hi,
My Mk2 has the common fault where the heated seats aren't working, i've changed the module with no luck and put it down to the wiring in the seats.
A replacement set is looking at £180+ for one seat... which i'm not paying.
Has anyone had any luck with any others from Aliexpress or anywhere else?
The parts in question are:
https://www.skoda-parts.com/spare-part/3t0963555af-insert-for-the-heater-seat-leather-skoda-26837.html
https://www.skoda-parts.com/spare-part/3t0963557q-insert-for-the-heat-up-backrest-leather-skoda-29544.html
I wondered if something like this could be retrofitted
https://www.aliexpress.com/item/1005006482145381.html?spm=a2g0o.tesla.0.0.2b91YxnhYxnhdk&pdp_npi=5%40dis%21GBP%21%EF%BF%A159.38%21%EF%BF%A129.69%21%21%21%21%21%40210385a817558600276202665e2404%2112000037367679053%21btf%21%21%21%211%210&afTraceInfo=1005006482145381__pc__c_ppc_item_bridge_pc_main__1aLhYdp__1755860027733
Daniel
  • 5 months later...
Have you tried, does it work? Same connectors and ohm?
I have the same situation, to expensive with OEM
No I haven't mate. I daren't risk it with it being such a big task. If it was a simple swap it wouldn't be so bad.
Had you considered taking the seat out and removing the covers to find the break and repairing? I did this when I had my range rover p38. The breaks are usually easy to find due to scorch marks.. I just soldered in fresh bits of wire and it worked a treat...
Not a bad idea at all that. My issue is (and solely my problem) is that I need the car daily and it's winter so would need it now. I may have a gander in summer time perhaps.
I also have done that earlier on another car, but my experience is that it easily breaks again. Maybe not on the repaired place but another weak place.
