Oil ash mass reset
Hello, how can I reset the oil ash level in my dpf, is this amount too much and what is the limit before I replace it with a new one. I would be happy if someone who knows and has done it could answer. Second question, what is the ID of the vcds measurement block where I can see what condition my injectors are in. I searched but didn't find it. The car is a 1.6 tdi 116 hp engine code ddya 2019
It will be all about the measured fuel and the pressure in the high pressure common fuel rail.
I would suggest that if the car has done over 120,000 miles, then you need a new set of injectors. Get some decent injectors (i.e. OEM or Bosch) and you shouldn't have issues.
My vcds doesn't have this "meas block" menu, older cars do, but mine doesn't show it as active.
