Mods to Fruby vRS Dashboard
Has anyone attempted replacing the 'cubby hole' in the centre of the dash (below the radio) with the push release drawer as fitted to the Fabia in Elegance spec? In a similar vein, anyone swapped the blank panels either side of the radio for the cupholders fitted in some models? If so, how easy/difficult was it? Any tips? Cheers!
IIRC NeoVR did the cupholder job on his car try searching under his username, the cubby hole insert and push release drawer are different and require the centre console changing
and welcome :cheers
Ive never seen the lil push draw... but it should be easy to do, as the cubby hole is only clipped in once the radio is removed... i might have to look into that :D
I've got the in-dash tray in my car and it's quite good for holding and hiding mobile phones and mp3 players or CD players. One thing about it is if it gets hot over 25 degrees the plastic expads and starts to rattle occasionally over bumps! There is a picture on my website of it and I'll see if it works here
(Which it doesn't for one reason or another)
Yes the drawer can be fitted.
I'll look up the part number...
