Headlamp day time light bars
69 plate
Any instructions on how to get inside the headlamp to replace the light bars?
the headlight is not suitable for this
But the bars can be brought as a kit?
AliExpress?
The DRLs r not designed to b replaced...at least not easily.
To get to it, u must remove the headlight front clear plastic which involves extreme heat using a heat gun or baking the headlights. Then u have to pry the plastic off.
Once the cover is off, u can access the DRL elements themselves as well as the DRL light circuit board itself.
Putting it back is a mess as well because u have to not only glue it back, it has to b sealed 100%.
A lot of effort.
And good luck finding the DRL elements specific for the Superb.
U can find the DRL boards though.
I haven't done it myself, but below r some pics from someone that has, showing the headlight with the front plastic cover off.....
